Page 1 of 2
MCL33 possible nose cone solutions
Posted: 16 May 2018, 16:36
by turbof1
I'm creating this topic specifically so that speculation can be made on the MCL33 ducts and outlets of the current nosecone. Since we do not have any pictures of the back/underside of the nosecone, multiple solutions are perhaps possible.
So guys, I'm actually breaking my mind on this one, trying to figure out possibilities how mclaren ducts their holes through the nose cone. The most standard option would be this:
The sideholes basically containing NACA ducts, moving underneath the centre duct, and the middle hole having stacked vanes, all for legality sake.
However, there might actually be another solution:
I'm not 100% sure on the legality myself. I believe the ducts separate are legal, but the combination might (or might not) create legality issues on overlap.
Basically this set up allows to get rid of the vanes in the middle hole, allowing airflow to move more unblocked through the duct. More over, this would fit the actual pictures taken from the nose cone better, as there is only a single strut visible on them. Legality vanes could still be in place however, just deeper inside the nose cone.
Re: MCL33 possible nose cone solutions
Posted: 16 May 2018, 16:53
by PhillipM
That also matches the heavily cambered shape on the underside of the outer ducts better.
The other thing I've been trying to see but we haven't had a clear photo of all weekend, is whether any of those ducts are blowing into the vertical fin that holds the cape - as it tapers in a 'v' from front to back, is it legal to have the back of that open?
(I'm thinking it would help accelerate flow around the side of it)
Posted: 16 May 2018, 16:55
by jjn9128
It looks to me like each of the side ducts is split into 2, maybe for helping legality (X-section/whatever), maybe for splitting the direction of the air. Does it help that it looks like side ducts are above the tip hole in the Z direction? It looks that way at least, difficult to tell as all images have a slight angle on them... A shot from underneath would really help to identify what's going on :lol:
Posted: 16 May 2018, 17:01
by turbof1
PhillipM wrote:
16 May 2018, 16:53
I think it can be legal if the open section is either NACA-ducted, or sits in the bulkhead area between 0mm and 150mm ahead of the front wheel centre line. Essentially any hole running like this:
is legal. And any holes sitting in that bulkhead area, are legal.
Posted: 16 May 2018, 20:14
by proteus
This is from Autosport, but it doesnt explain the middle very well:
Posted: 16 May 2018, 23:13
by trinidefender
proteus wrote:
16 May 2018, 20:14
https://www.youtube.com/watch?v=3Ho0KVIYMbk
There are some glaring errors with that explanation.
Firstly while yes a vortex might form at the edges of the sides of the cape due to the lower pressure below and higher pressure above, it won't be a very strong vortex. Primarily due to the fact that there won't be that much of a pressure gradient. There isn't much of a curve below the cape to increase airflow velocity and drop the pressure.
Secondly, people keep comparing this to the Mercedes concept when in actuality they are quite different. The key difference being the direction that the vortex (if this cape even creates one of any substance) rotates.
On the Mercedes, the cape has the pieces at the very front which purposefully trip the airflow into a vortex. The higher pressure below rolls onto the top into a vortex as shown in the picture of the F-18.
As you can see looking at that picture on the left side the vortex is clockwise, on the right, it is counterclockwise. On the McLaren setup if there is a vortex, looking at the nose from the front, on the left the vortex would roll counterclockwise on the left and clockwise on the right.
The reason why this detail is so important is the inside vortices coming off of the front wing. On the Mercedes they will be co-rotating and on the McLaren they will be counter-rotating. Co-rotating vortices gain strength, counter-rotating tend to cancel each other out. Considering how close together they are and the front wing vortex being much stronger, I wouldn't be surprised if it cancels out any vortex created by the horizontal section of the cape
I'm pretty sure the cape (and the rest of the nose) is more about setting up airflow for the rest of the car rather than providing its own downforce component.
Posted: 16 May 2018, 23:17
by roon
I think the long thin bars running the length of the front corners are for yaw. Turning air down the leeward, otherwise stalled, face.
Posted: 17 May 2018, 16:57
by Jef Patat
Posted: 17 May 2018, 21:05
by proteus
trinidefender wrote:
16 May 2018, 23:13
proteus wrote:
16 May 2018, 20:14
https://cdn.pbrd.co/images/HiqUTlg.jpg
http://www.lerx.net/Arbre/Lerx/Data/FA18D%20LERX.jpg
http://rumourcontrol.com.au/wp-content/ ... chell.jpeg
Thank u for youre comment and explanation. I really enjoyed reading it, i am not the sharpest tool in the shed about aerodynamics, so i really appreiciate youre knowledge and understanding of it. So again, thank u very much :)
Posted: 17 May 2018, 23:38
by turbof1
So based on the confirmed outlets, kudos to Piola having those exits so accurate from to get go, I revised my idea of the ducting. So jjn9128, I don't think they actually split the side ducts, but I do believe they make an X-section:
Posted: 18 May 2018, 00:12
by jjn9128
turbof1 wrote:
17 May 2018, 23:38
http://u.cubeupload.com/turbof1/XDucts.png
Really? It looks to me like the wide centre outlet is split three times. I can see a shadow about 1/3 along on the left which looks like where it is split ever so slightly set back... so the central duct and inner ducts of the outer ducts go to the middle, with the outer-outer ducts going to the edges... if that makes sense...
What you're suggesting would be quite a sharp turn... I would have thought the loses would make the ducting quite inefficient. I think you'd also see that difference in angle on the head on shot!
Posted: 18 May 2018, 00:37
by turbof1
jjn9128 wrote:
18 May 2018, 00:12
turbof1 wrote:
17 May 2018, 23:38
I could make the turn more fluent, yes. Let me give it a shot, one moment.
Posted: 18 May 2018, 00:47
by turbof1
I think this will work better in yaw.
You could of course still be right, as there are some structures in the outer inlets. However, splitting these outer ducts will create even more complexity, and since there are only 3 outlets in there, and splitting the outer inlets will create 5 ducts in total, means you somewhere along the way are going to merge ducts. Not counting in the splitting of the centre inlet.
I could be missing the point, but what's the gain from splitting into so many ducts? Solving the legality puzzle can be done a multitude of other, less complicated ways.
My impression is that these structures we see are small turning vanes, to straighten flow.
I will also try to get an impression of your idea tomorrow. There might be some benefit to be found in getting smaller tubes with softer turns.
I'm also working on those other illustrations for the record.
Posted: 18 May 2018, 06:22
by PlatinumZealot
turbof1 wrote:
17 May 2018, 23:38
It's all wrong. Try again.. 8)
Posted: 18 May 2018, 09:58
by turbof1
18 May 2018, 06:22
turbof1 wrote:
17 May 2018, 23:38
I did already. Spot the 10 differences 8).
