adjustable front wing usage?
Post Mon Mar 30, 2009 12:58 am
Do you know if some used the movable front wing?
vall
Post Mon Mar 30, 2009 2:12 am
Sry, can't tell.
Mclaren-Mercedes + Hamilton => dreamteam!
De Jokke
Post Tue Mar 31, 2009 12:33 pm
I'm disappointed that the movable front wing setting is not included on the in-board graphics along with revs,gear,KERS.
It's a massive change in the regs to have movable aero devices, so to not let the viewers know when it's being used is a mistake in my opinion.
Henning
Post Tue Mar 31, 2009 12:42 pm
I am of the opinion that currently the teams and drivers are using the adjustable front wing just for trim. During both the race and qualifying I carefully watched when anyone was changing from one tire compound to another. On the ones I did observe, there were no front wing adjustments made. Considering how everyone states that there is an unbalance between front and rears, and that changing compounds only magnifies the problem, I assume that any time a team goes from hard to soft, or vice versa, front wing trim would be altered. But it didn't happen, and thus my opinion is that they trim out the differences with the adjustable tab.
There has beeen only one race so far, and it's possible everyone is easing into the warm waters of change. Maybe the drivers were not tasked with worrying about the wings, because they had to become adapted to the KERS. Sometimes it's not good to throw too much at anyone, because people need time to assimilate the experience. There's no experience than trying to do the job during the heat of competition. Quite different than testing.
A proud Canadian, and yes, HOCKEY is our game.
DaveKillens
40
Post Tue Mar 31, 2009 2:26 pm
DaveKillens wrote:I am of the opinion that currently the teams and drivers are using the adjustable front wing just for trim. During both the race and qualifying I carefully watched when anyone was changing from one tire compound to another. On the ones I did observe, there were no front wing adjustments made. Considering how everyone states that there is an unbalance between front and rears, and that changing compounds only magnifies the problem, I assume that any time a team goes from hard to soft, or vice versa, front wing trim would be altered. But it didn't happen, and thus my opinion is that they trim out the differences with the adjustable tab.
hmmm, if I remember correctly, there were allowed to change only once per lap and then return to original position?
vall
Post Tue Mar 31, 2009 4:21 pm
I think it should be outlawed.
What if a driver in the heat of battle, forgets to change in to the "high downforce" setting before a corner and understeers into the wall?
I'm assuming that the wing is trimmed out for the straights and then returned for the corners.
Along with KERS there are too many buttons to play with, not to mention shifting 8 gears!!
G-Rock
Post Tue Mar 31, 2009 4:33 pm
yeah, it is getting busy in the cockpit. I think the idea is to increase the angle and hence the DF when following a car. This should compensate for the DF losses due to turbulence behind the car and make overtaking easier
vall
Post Tue Mar 31, 2009 4:37 pm
vall wrote:I think the idea is to increase the angle and hence the DF when following a car. This should compensate for the DF losses due to turbulence behind the car and make overtaking easier
Yup.
I think the system would need to be automated to fully unleash the potential.
It shouldn't be too difficult to do based on the difference in deflection between front and rear suspensions.
Front suspension compression less than rear* = more front downforce
Front suspension compression more than rear* = less front downforce
Obviously, it will need a function to describe a variance as the rear has softer springs than front.
Also, the system would need to consider braking & acceleration.
But its not too many variables. Certainly compared to an engine map it can be approximated much simpler.
kilcoo316
Return to General chat
Who is online
Users browsing this forum: Diff-user and 12 guests
