Renault R31
227
Re: Renault R31
Too heavy, they would just use a bladder i guess.
It's bolted to what looks like electronics. Could be a coolant reservoir for KERS?
manchild
manchild
Re: Renault R31
Been looking those pics and zooming for a while.
I know this will sound at least far fetched if not crazy, but I think that it is the pressurized chamber for inflating of G-suit.
Michiba
Michiba
Re: Renault R31
avatar wrote:
madly wrote:Zgred thanks, great photo!
Below HiRes version with brightened dark areas.
and HiRes link: http://sliwinski.priv.pl/f1/r31_fee_2011_03_24.jpg
EDIT: typo
On the canister thingy; I doubt it is this, but what size reservoir would you need for a hydraulic KERS setup?
This image should give you a better idea of the intake.
although, this is on the other side of the car, so the left side might be different.
JohnsonsEvilTwin
Re: Renault R31
Renault heat signature.
More could have been done.
David Purley
Carlo's
Carlo's
Re: Renault R31
Scarbs:
Renault front brake ducts, the small outer scoop looks likes it's aided by the inlet inside the vane
nacho
nacho
Re: Renault R31
Is that KERS-equipment under the right radiator.
227
Re: Renault R31
this car spit out some flames in q1, anyone have any HD shots?
zgred
Re: Renault R31
korzeniow
korzeniow
Re: Renault R31
@zgred, thanks for the photos. There are revised cooling outlets at 1st photo.
February 5, 2013
mith
Re: Renault R31
I also think they're revised cooling outlet, which now looks bigger.
TURU
TURU
Re: Renault R31
There is one thing about R31, more precisely its exhaust system that made me wonder. What impact can it possibly have at the start of the race.
I mean it blows under the floor and since exhaust gases are quite hot, one could imagine that maybe, just maybe it can heat up the tires or the track surface in front of rear wheels giving them better grip off the line. Are we going to witness some atomic starts from Renault? What do you think?
747heavy
Re: Renault R31
not sure, if it makes much of a difference under "normal" conditions, but
if we see a wet race start, or slightly damp track, I would not bet against it.
- Colin Chapman
marekk
marekk
Re: Renault R31
TURU wrote:There is one thing about R31, more precisely its exhaust system that made me wonder. What impact can it possibly have at the start of the race.
Only if they go the few last meters to the start line very, very slow, to get some heat into the tarmac.
But it certainly can help to get more heat into rear tyres on formation lap and behind safety car.
korzeniow
korzeniow
Re: Renault R31
marekk wrote:Only if they go the few last meters to the start line very, very slow, to get some heat into the tarmac.
It should help with starts on the green side of the track
February 5, 2013
Re: Renault R31
So in fact, the exhausts are passing under radiators disposed a la Macca/RBR and not between the chassis and two classicly disposed Renault radiators...
That means Renault could 'easily', if they want, replace its FEE system with another interesting concept: STR sidepods + rear exhausts !
The front brake ducts they run since the first tests (first version) are interesting as well. :)
