Aston Martin AMR24
Re: Aston Martin AMR24
Waz wrote:
09 Apr 2024, 12:23
diffuser wrote:
08 Apr 2024, 16:12
Waz wrote:
08 Apr 2024, 15:45
I'm curious about these. It's obviously a non-rotating part, and looks like it's creating an outwash? Am I correct?
But isn't the wheel fitting over these with a cover that prevents outwash? What am I not understanding properly about the intended effect of these?
I haven't seen any other photos of a team with fins like this on the brake covers.
Thanks in advance for the more knowledgeable people who normally come to the rescue and answer these questions.
Like you said the wheel will spin. This will cause the air to spin in there and the rim will block the exit to the outside but I think that's trying to pull the air inwards instead of staying stagnant in an effort to decrease hotspots.
Ahhh, thanks, I didn't think about the effect of wheel spinning affecting them.
So it's more about brake temperature control than directing air. Interesting solution , and I remember the AMR23 having some brake temp issues.
In this picture, on the left tire on the upper right hand side of it, you can see the air egress brake duct.
KimiRai
KimiRai
219
The big vertical dropoff from the waterslides looks to have been reduced a bit. (B Sport picture)
05 Apr 2024, 12:06
AMuS - some great comparison shots with the old spec
wiktor977
wiktor977
I don't know if this was noted here before but there is a significant change to the floor leading edge inboard. Would love to see better pictures to compare changes more in detail.
wiktor977
wiktor977
Another thing that I've noted are new (not yet used during the race this season) winglets on the rear wing endplates. Solution used last year by Alpine and Aston, this year more teams have joined with their (very similar) designs.
I think we might see this RW being used by Aston on some high-downforce demanding tracks.
Japan, 2024
2023
KimiRai
KimiRai
219
Suzuka vs Bahrain
wiktor977 wrote:
17 Apr 2024, 00:44
Im sure we'll get better photos, for now that is the best I could find.
abhi1200
abhi1200
34
aston at shanghai.
SSJ4
SSJ4
SSJ4 wrote:
19 Apr 2024, 15:12
That's just extra cooling. If anything, it would hurt aero. It's a must so they're gonna find ways to minimise that loss. You want as much hot air hitting the beam wing.
diffuser wrote:
19 Apr 2024, 17:31
SSJ4 wrote:
19 Apr 2024, 15:12
It's not particularly warm in China. Interesting. I would have thought that we would see this earlier. Is it really "extra cooling" or it is simply a redistribution of cooling outlets to optimize the existing cooling?
19 Apr 2024, 17:46
diffuser wrote:
19 Apr 2024, 17:31
SSJ4 wrote:
19 Apr 2024, 15:12
When you mentioned that I looked for pictures of the gills below the cannons at the rear. They're still there.
There was also mention that the didn't use all the upgrades in Japan. Maybe that's what they are. The turbine is there, maybe the just need better flow tgere. Whatever it is, it's not a big change.
KimiRai
KimiRai
219
ANDY238
ANDY238
:o
SSJ4
SSJ4
SSJ4 wrote:
29 Apr 2024, 14:29
I wonder if that front wing change they made at , was it race 2?, cleaned up the air flow to allow for that change.
SSJ4
SSJ4
diffuser wrote:
29 Apr 2024, 17:55
SSJ4 wrote:
29 Apr 2024, 14:29
Iirc saudi was something to do with front brake drum and Australia they adjusted the front wing flaps. I wonder what they saw in terms of development potential
