Would it be possible to cast the combustion chamber half as part of the block and fit wet liners from the bottom?
I still think the old Bristol clunk head sleeve valve concept has potential.
n smikle wrote:I forgot you could do that..![]()
The original plan was to have it fit to current engine blocks, but yeah it seems that it has to be a special block.
Would make it interesting. I never drew a whole engine block before.
riff_raff wrote:n_smikle,
The manufacturability of that rotary valve head is the least of your worries. Heat transfer, combustion gas sealing, seal friction losses, and valve seizure due to lack of lubrication, thermal distortions and combustion pressure deflections, are much more difficult issues to deal with.
The biggest issue I can see with your model, is that you have very hot, high velocity exhaust gas flow passing over a thin, uncooled, thermally isolated, aluminum port edge. The exhaust heat transfer in this port edge will quickly cause it to melt away.
Nice models, regardless!
Terry
Terry
n smikle wrote:
This engine is very different from mine. In my version the valves go in the place of were a typical overhead camshaft would be. Its not a sleeve design like that one. But still interesting none the less. I wonder if the sleeve design would be good for Formula1?
Here's a rotary valve engine Ilmor Engineering built for F1:
http://www.v-eight.com/multimedia/pdf/AutoTechBRV.pdf
http://www.leapaust.com.au/about/casest ... rrocks.pdf
By all accounts, it worked pretty well. But it was made illegal before it ever raced.
Regards,
Terry
n smikle wrote:gcdugas wrote:The intake and exhaust gain nothing from being independent.
The exhaust valve is very hot so that means that if the exhaust and intake valve is one and the same then you have a hot intake valve.
autogyro wrote:The main problem in the Bishop valve is the heat from the exhaust port in the rotary valve transferring to the inlet port through the uncooled thin wall.
Return to Engine, transmission and controls
Users browsing this forum: No registered users and 2 guests
