GP JAPAN - SUZUKA
Undergone changes from Singapore
1.New Virgin logo
2.Front brake disc holes
3.Exhaust outlets , hot air exits at the rear zone
4.Rear wheel rim shields were brought back into use
5.Rear wing
horse wrote:Looking at the images, I would say the diffuser central channel changed in Singapore. You can see the curved section has been bridged above the starter hole and this can been seen in the later pictures also.
horse wrote:Regards the asymmetric end fence at Interlagos, this appears a trick of the light. The "bent back section" on the right top edge of the diffuser is reflecting white which makes it appear to be missing. This makes the end part appear larger than the one on the left hand side.
TRICKLE69 wrote:It seems to me that on the bottom right of the diffuser there is pavement shown in the picture that looks exactly like part of the difusser/endplate..
axle wrote:TRICKLE69 wrote:FRONT BRAKES JAPAN
Could it be that 1 is Button's and 1 is Ruben's? As they like different rotors don't they?
Users browsing this forum: Jon_S and 4 guests
