Monstrobolaxa wrote:hummm.....no!
Using carbon fibre reinforced plastics as in the monocoque...isn't viable cause the epoxy resin in the combustion chamber would overheat and "burn".
Using a carbon base like the brake discs and pads wouldn't work either...once again inside the combustion chamber the friction between the piston and the wall...and the heat would wear out the wall and would also oxidize the carbon....
manchild wrote:Monstrobolaxa wrote:hummm.....no!
Even with wet liners made of metal?
Anonymous wrote: what can be done is creating a carbon based alloy. We have sucessfully utilised this material in pistons for our model car engines with not only decreased wear rate but also increased power levels.
Return to Engine, transmission and controls
Users browsing this forum: No registered users and 6 guests
