timbo wrote:Understeer = stability but no control
Oversteer = control but no stability
Not true.
On the original point of the discussion though.. first thing is you have to define what you're calling 'oversteer' vs 'understeer' or 'tight' vs 'loose.' It's not as straightforward a definition as you'd think, at least in a practical (rather than textbook) sense.
Second, broadly saying a car is 'u/s' or 'o/s' or that a driver prefers one or the other is useless IMO. Measures of balance, stability, and control are a sliding scale, not a binary attribute, and change dramatically with vehicle speed, steering throttle and brake inputs, etc. You can have a car that's free on the brakes and tight on throttle.. or tight on the brakes and free on throttle. Just breaking a corner down into "entry - middle - exit" isn't as insightful as breaking balance down by input. Depending on the type of vehicle, the track, the corner.. varying degrees of vehicle handling can be fast or slow.
For example, having a stock car half sideways through to the center of a tight corner is probably going to have a lot of potential for speed... whereas it would ruin you in an open wheeler.
I would also not agree that 'oversteer' is good for having a car change direction.
In any event, all F1 cars are going to be set up very very close to neutral through most of the lap. If you're not using all of your front or rear tires, you're leaving speed on the table.. period. Preference differences between drivers are going to be very, very slight.
Grip is a four letter word.
2 is the new #1.
