Yep absolutely correct.
One ramps down, the other ramps up, brilliant you understand how it works.
Now tell me how long it takes to ramp up one ring and ramp down the other.
Ipso facto a time gap. Not seamless.
autogyro wrote:One ramps down, the other ramps up, brilliant you understand how it works.
autogyro wrote:Now tell me how long it takes to ramp up one ring and ramp down the other.
autogyro wrote:You can of course transmit torque during the 'time' the bullets are ramping up and down.
autogyro wrote:you will either slip the contact points of the bullets, jam the system
autogyro wrote:I also did consultancy work for both Borg Warners
autogyro wrote:NO.
DCT gearboxes will always loose at least part of the available torque in clutch slip.
Cogs wrote:autogyro wrote:NO.
AAAAaaaaaargh!!!!
I know this, this was never part of the discussion, of coarse DCTs loose part of the available torque in clutch slip, this is during a period where output torque is changing though so the reultant loss is not significant when measured at the output. By the way my involvement with BW was not in the 70s but during the development of DQ250 so don't preach about what you think is measurable at the output shaft of a DCT.
Zeroshift is an evolution of a dogbox the reduction of fuelling or ignition does not need to occur until post shift event, at which point clutch modulation can substitute the lost torque to the input shaft.
autogyro wrote:So far you have failed to explain the time gap between being engaged in one gear and being engaged in the next gear.
To be seamless, there needs to be no time between the two states.
Return to Engine, transmission and controls
Users browsing this forum: No registered users and 6 guests
