McLaren MP4-26 Mercedes
chepoi
chepoi
Re: McLaren Mercedes MP4-26
Halgovern wrote:Racecar-engineering on its twitter page :
'McLaren's 2011 KERS - a bit less electronic & a bit more hydraulic. MP4-26 nose also looks a bit like TF110 but fatter'
may be like this?
after seeing this i can say one thing, it will be the same nose as the MP4-25 but without the nose splitter.
bonjon1979
bonjon1979
30
spinmastermic wrote:Why is Lewis in the number 4 car next year?
He got more points than button this year. It seems a bit odd but maybe he prefers even numbers?
He's not:
http://www.fia.com/en-GB/mediacentre/pr ... entry.aspx
Good to see Scarbs back on this board - i missed his input for a lot of last year and it's always appreciated.
Does anyone have a link to the technical regulations for next year? I notice on the FIA website that the technical and sporting regulations for 2010 weren't published until halfway through the season. Can this be right?
The reason why I ask is because I thought it might be interesting to see if any of the boffins on here have any innovative ideas that get around the rules before we see them on the cars. In particular I'm interested in the rear wing - on the surface of it, it should be quite simple but I notice that Ferrari have already said that they hope that the interpretation of the rules doesn't mean someone can exploit a loophole. Any thoughts? Could the beam wing also be made to actuate as well as the main plane?
murtoidf1
murtoidf1
So the 2011 mclaren nose is like the toyotas but fatter.
and it seems to be that the 2010 nose is like the toyotas but fatter too.
so the nose looks the same lol
McLaren were the only team that went for a high flat nose last year, it was a brawn and red bull mix.
also were mclaren the only top team without a groove in the nose because the suspension arms were mounted higher?
marcush.
marcush.
159
Mclaren had their steering rack low in the tub ,that is the reaoning behind not having the crosssection modified a la RedBull.It´s a tradeoff,as always.
Mandrake
Mandrake
In 2010 McLaren's nose was lower than the TF110's nose. The way I understand the Racecar Engineering tweet is that McLaren will also use this high nose approach Ferrari and RedBull went for this season, only that it will be thicker. It goes into the same direction like Renault, which are said to develop a nose which resembles an old Benetton nose.
wrcsti wrote:Its an e30 after all.
I know, it's just been an off-topic posting to put diffuser size into perspective :)
(Driving an e30 myself I prefer my stock version without the Diffuser, works well for me :p)
gridwalker
gridwalker
Apparently, this is Jenson's seat fitting in the 26 ...
There's not much to go on, but it is the first official sighting of (bits of) a 2011 car ;)
on this view the tub seems the same compared to the MP4-25, also look how the head support fits perfectly behind jensons helmet, it is an similair shape.
Personally I think McLaren will go back to a lower nose, as an low CofG is pretty important.
timbo
timbo
111
wesley123 wrote:on this view the tub seems the same compared to the MP4-25, also look how the head support fits perfectly behind jensons helmet, it is an similair shape.
Yeah. His helmet looked a bot too far out in MP4-25
Henning
Henning
The scalloped leading edges to the sides of the cockpit (head protection) are new. I wonder whether they will be channeling air to some aerodynamic device or just weight saving?
I believe the 25 had these too, headrest area just seems the same
ell66
ell66
murtoidf1 wrote:So the 2011 mclaren nose is like the toyotas but fatter.
i think you need to have a closer look at some of last years cars...there were cars other than mclaren with a "high flat nose" williams being one of them.
228
I hope the car is not too big. Jenson is looking pretty small in there.
He can't even look to the side. :lol:
chepoi
chepoi
gridwalker wrote:[img]http://sphotos.ak.fbcdn.net/hphotos-ak- ... _n.jpg[img]
on website they called it 26A..... it might be called MP4-26A IMHO
astracrazy
astracrazy
31
It will be MP4-26
The A i have a feeling is more to do with the version of the chassis or something like that?
