ringo wrote:Yes an active system can be mistriggered, but it would simply stabalize itself; This would come in the form of the driver's input.
An active system simply would not behave erratically as Shu described it.
marcush. wrote:oh closed loop vs open loop ....
my favorite.
A hand operated f-duct is nothing else than steering a car or applying throttle.Input is given by human and the system responds to it with a defined answer.so clearly a closed loop as long as no secondary parameters are f.....it up.
If your f-duct is using a secondary input to allow or reject activation -lets say ambient temperatur ,or jaw angle I´m convinced it has open loop capability.
timbo wrote:ringo wrote:Yes an active system can be mistriggered, but it would simply stabalize itself; This would come in the form of the driver's input.
Renault said that Petrov's crash at practise in Brazil was due to F-duct malfunction that failed to come back into "closed" state.
my favorite.
ringo wrote:It would be nice if any of you here could put up a schematic of the system.
With the actual air path way and plumbing.
marcush. wrote:I do not want to be nitpicky ,but open loop is a system thatt is reacting to = correcting for outward disturbances ...a system that is governing itself to achieve the desired result for a given input.slowish input signal from an old driver is still an input and will be translated into activating the f-duct..
A characteristic of the open-loop controller is that it does not use feedback to determine if its output has achieved the desired goal of the input. This means that the system does not observe the output of the processes that it is controlling. Consequently, a true open-loop system can not engage in machine learning and also cannot correct any errors that it could make. It also may not compensate for disturbances in the system.
To blame the nose is a silly mistake IMO.
For all we know that nose is better than the rest of them and by some considerable margin.
It could be suspension, driver location or loads of things causing the issues.
adam2007 wrote:ringo wrote:I think it's the tub, not directly, but because the tub determines how things are packaged longitudinally right?
Obviously the car was made short by moving the driver forward to get room for the tank and trim down the rear body work.
If you look closely you can see shumachers bum teetering over the splitter, driver placement could be the problem for the weight balance and under steer, who knows?
Secondly i don't think that the COG height is one of the major problems. It's not like last year where they had to improvise with the gearbox and Merc engine, so i think the team would be weary of COG height this year and probably go to extra lengths to get it as low as possible.
Visually i think the driver COG is too far ahead, affecting front aero, because the front has to be bulky to accommodate this, and affecting the balance because driver is to far ahead with such a short wheel base.
Merc need to get Shumacher's ass out of that area.Push it back and put the thy at a steeper angle to cut down the front end bulk. I don't think shifting the weight of the thy upward and having a minute increase in COG because of it will outweigh putting the COG backward for a better balance and the other aero benefits that come with it.
Then again this is all tub design, so i don't know if it can be changed, though increase in wheel base could effectively get some of these things done.
makes me laugh you guys trying to say this is how to fix the problem, leave it to the professionals they spends thousands hours in labs and wind tunnels analzying it all. they know a hell lot more than you, if that easy email mercedes and tell them how to improve the car
F1_eng wrote:JohnsonsEvilTwin, why would anyone choose any part with more drag unless it gives a load more downforce?
You honestly don't have any idea what you're on about. A high nose like other teams can be analysed in a few minutes in the wind-tunnel so if it was better, it would have been implemented.
What is people's obsession with the nose design?
Why do you suggest the Merc nose creates more drag?
How about the McLaren front? What about the area under their nose that tries to replicate the effect of the Merc nose?
Users browsing this forum: -Tifosi_dude-, Pierce89, tepek and 17 guests
