WilliamsF1 wrote:How did this car steer, looks like that part is missing.
In the second photo you see the steering rod & steering arm better.
back at this time, not every F1 car had their steering rack infront of the front axle.
Ciro Pabón wrote:...on hard suspensions, as God intended for race cars to have, it's minute....
Ciro Pabón wrote:...I guess that's one of the reasons why good F1 drivers start at kart races, because the suspension of an F1 car, at 600 kilos, and with such large tyres, moves very little...
riff_raff wrote:DaveW is correct about karts. While they do not have a conventional suspension, they still have many chassis adjustments that can be made to change handling. The spindles can be changed for caster, kingpin, camber, offset, etc. Tire pressures can be changed. Wheel spacers can be used to alter track. And some classes use an interchangeable rear chassis bar to alter torsional stiffness.
Users browsing this forum: Baidu [Spider], Google Adsense [Bot], MOWOG, Twitter [Bot] and 7 guests
