Roll Center Migration
Post Tue Aug 23, 2011 11:19 am
Hi,
I want to design a race car without antiroll bar because it is not very easy to install it in the car.
In order to reduce the roll angle I want to design a geometry with the roll center moving outside the corner when rolling. I think that it will reduce the roll angle.
Do you think that it is the case?
Thanks.
ghost406
Post Tue Aug 23, 2011 12:00 pm
And why do you think this?
Why not just add more spring?
Grip is a four letter word.
2 is the new #1.
Jersey Tom
130
Post Tue Aug 23, 2011 1:40 pm
Jersey Tom wrote:And why do you think this?
because more spring will reduce the grip :(
ghost406
Post Tue Aug 23, 2011 2:02 pm
What does an anti-roll bar do if it doesn't reduce grip? The bar literally links one wheel to the other taking load off one wheel and adding it to it's partner.
It seems to me that getting a roll centre outboard and controlling it's position in bump, roll, droop and all the combinations of the above going through a corner would be much harder to achieve than to find space for an ARB. And can you do all that and keep a sensible camber curve for the tyre?
Keep it simple.
RH1300S
Post Tue Aug 23, 2011 7:56 pm
I'm not sure about that. Throwing more spring on might increase the roll stiffness of the car making it seem like it loses grip, but I think in actuality that it takes less time for the tires to build up and reach there max cornering potential sooner. In my mind stiffer car takes less time to transmit forces laterally and longitudinally than a softer sprung car does.
fastback33
Post Tue Aug 23, 2011 11:26 pm
I think you should rather try to get somehow a anti roll bar into the car than trying to change the suspension in some very strange way which possible can never completely eliminate the need of a ARB.
Sounds like you are going to take some really bad compromises.
Why can't you find a way to get a ARB into the car?
mep
Post Wed Sep 07, 2011 11:31 pm
You might do better moving the roll center vertically, i.e. closer to the center of gravity, to reduce roll. That's what NASCAR does by adjusting the heigth of the Panhard bar. But if you eliminate roll the driver won't appreciate it. And adjustability of the roll resistance/height is often convenient.
olefud
59
Who is online
Users browsing this forum: Google Adsense [Bot] and 8 guests
