The side gurney is something I'd not considered. I think it'll increase frontal area though, which will increase drag. With only 185bhp, I need all the help I can get down the straights! I think venting the wheel arch to inside the sidepod will result in less drag as the inside of the sidepod should be low pressure as it shares space with the area behind the radiator. The splitter looks shorter than it is in that photo. It's about 100mm long at its shortest.
Ideally, I'd like to rebody the whole car but time and skills are in short supply! There's a lot of scope to make more of a Coke-bottle shape of the rear, move the radiator somewhere less prominent, reduce frontal area and make a decent stab at a front diffuser. One step at a time...
