Placeholder diffusor.
I think you can literally discount pretty much everything about this car apart from the general layout....
Rear packaging looks quite efficient (single point), though not quite FW34esque with ultra low gearbox and acutely angled drive shafts.Crucial_Xtreme wrote:Here the rear cooling is quite visible and quite low.
Yeah, that's the result of utilising the now free octopus-area + a probably smaller gearbox too IMHO. Any confirmation yet on new(smaller) gearbox ?Crucial_Xtreme wrote:Here the rear cooling is quite visible and quite low.
EDIT: Do you mean inlet rather than outlet? Anyway, most of this post still works.Giblet wrote:The extra cooling outlets appear in the radiator openings now I think.
nee '33 of course!sAx wrote:Rear packaging looks quite efficient (single point), though not quite FW34esque with ultra low gearbox and acutely angled drive shafts.Crucial_Xtreme wrote:Here the rear cooling is quite visible and quite low.
sAx
not a duct from the tip of the nose where the pressure is high to vent the pressure behind the low pressure void of the front wheels? Even a small increase in pressure behind the wheels would allow more of the turbulant air from the tires to detach and flow better down stream over the body? Reduce drag tooBlackout wrote:Gridlock wrote:
