marcush. wrote:600.000€ for a tub? jesus how much are them paid those laminators? In my book a tub is sure some square inches of cloth and honeycomb but the main issue must be labour ...assuming a guy is worth 80or so € per hour you are claiming they need 6000 or something hours to lay up a tub? in other words ,to get a tub ready in 6 weeks that is 12 guys working flatout 7 days a week
12 hours per day..sorry don´t buy that.Somethings wrong in this calculation.
i believe 600 to 1000hours is a possibility all things counted...but the cost is not just stemming from material and labour to produce the actual bit ...the real work has gone into producing the molds .
ESPImperium wrote:Carlo's wrote:Big blow, Lotus is packing up and heading home:
http://www.autosport.com/news/report.php/id/97616
That is a big blow. This also means that they will have to re-crash test a chassis as well as its outside the homologation of the design they submitted.
This is as big a blow to the team as the one they had last year loosing Bobby K in my opinion.
Their E20-03 will also have to be modified as well, and also when it comes to E20-04 onward the solution should be in the build.
Im now looking at Lotus to have the E20 with 6 chassis by the end of they year now. Id recon they will run with 01 to 03 for the first 4 GP, then go toMugello with the first of the new homologation, then have brand new chassis for the rest of the year.
This is costly on a financial sence as well, as a Chassis to 2007/2008 costs cost arround €600,000, so id recon this is close to the €700,000 mark now, if not more. It also diverts resource away from dialing in performance into the car as well in a set up stand point at present and later a aero point of view as well.
Owen.C93 wrote:marcush. wrote:600.000€ for a tub? jesus how much are them paid those laminators? In my book a tub is sure some square inches of cloth and honeycomb but the main issue must be labour ...assuming a guy is worth 80or so € per hour you are claiming they need 6000 or something hours to lay up a tub? in other words ,to get a tub ready in 6 weeks that is 12 guys working flatout 7 days a week
I think there's something like 300-500 layers for the tub. Not exactly an easy job.
How it is possible that a flaw in the construction of the tub didn't show during the load tests in the factory and showed after just few laps on the track?
Users browsing this forum: Chuckjr, Yandex [Bot] and 10 guests
