Adrian Newby wrote:Decreased sealing wouldn't stall the diffuser, it would allow more air in from the sides, decreasing the low pressure zone.
Assuming you can get the effect that you propose, I have an issue with the imbalance it creates over the range of turn speeds. You would need a compensation effect to maintain the cars balance in all types of turns.
Brian
