A car with 2X power weight Downforce half CdA beat an F1?
g-force_addict
g-force_addict
2X power, 2X weight, 2X downforce, yet half CdA
Would such a car beat an F1?
Despite weighing twice as much power to weight ratio is the same.
So in theory low speed acceleration would be the same.
The car would have a higher top speed because of the lower CdA.
What about the corners?
machin
162
Re: A car with 2X power weight Downforce half CdA beat an F1
Depends on the race track -around a high speed Oval -almost certainly it'll be quicker...
Around a go-kart track; almost certainly slower....
thisisatest
thisisatest
are the tires bigger? wider?
Weight stays the same but downforce increases with the square of the speed increase. So, are you saying it has twice the downforce at a given speed e.g. peak speed or that the aero devices have a lift coefficient twice that of the other car?
And then what about tyres? Are they the same in both cases?
Sounds like you need to define the problem further - too many variables to give any sort of answer really.
