Sauber C31 Ferrari
Post Wed Mar 28, 2012 7:05 pm
last week the flow looked like this (I know the spec is a bit different, but the inside vane stays in place.)
I doubt that the flow is jumping the vane to reach the slit, maybe the flow is split by the vane, but I doubt that this Piola guess is correct. We have seen on Maldonated's car the power/direction of the exhaust flow.
"Results never tell the full picture. You need to take a close look at the story behind those results." raymondu999
FrukostScones
Post Wed Mar 28, 2012 7:17 pm
FrukostScones wrote:I doubt that the flow is jumping the vane to reach the slit, maybe the flow is split by the vane,
Of course it isn't.
[Expect the irate reply from those obsessed with it in 3-2-1]
kilcoo316
Post Wed Mar 28, 2012 7:31 pm
FrukostScones wrote:last week the flow looked like this (I know the spec is a bit different, but the inside vane stays in place.)
Whether it does or doesn't, I'm not quite sure obviously, but both of these pictures come from the same place. However the slit/cut would be there for the purpose of getting some flow under the floor. As you said, perhaps it splits the flow?
@kilco0316 surely you weren't referring to me?
Crucial_Xtreme
Post Thu Mar 29, 2012 4:07 pm
blokkie wrote:Image
Only on the sauber it's entry and exit is on the nose itself .
Can this really work without a device speeding up the air between the 2 holes?
AnthonyG
Post Thu Mar 29, 2012 5:33 pm
There's high pressure building up beneath the nose and the duct feeds into a relatively low pressure region created above the hump in the nose...
scarbs
Post Thu Mar 29, 2012 5:38 pm
Why should the flow there go around a 90° corner?
It has some inertia and high air speed. It will create lots of turbulence for very little flow going trough the hole. I can't see how this should be benefical at all.
mep
Post Thu Mar 29, 2012 8:31 pm
mep wrote:Why should the flow there go around a 90° corner?
I think that 90° corner has to do with the mechanical bits at the front of the survival-cell.
AnthonyG
Post Thu Mar 29, 2012 8:37 pm
I noticed looking through pictures that Checo's car did not use a monkey seat in Malaysia, and Kobayashi did. Interesting no?
Checo
Kamui
Crucial_Xtreme
Post Thu Mar 29, 2012 8:47 pm
The whole purpose of the slot both under & over is to get better airflow to the underside of the car.
Crucial_Xtreme
Post Thu Mar 29, 2012 8:52 pm
scarbs wrote:There's high pressure building up beneath the nose and the duct feeds into a relatively low pressure region created above the hump in the nose...
Ok, I understand.
And Red Bull is probably doing the same with the 2 slots, but then feeding the air to the (low pressure) cockpit?
AnthonyG
Post Thu Mar 29, 2012 9:13 pm
I think they did the same in Australia, running one car with monkey seat and one without. Or it might have been during practice, but look it up.
Edit: Yes they did in Melbourne aswell
Huntresa
Post Thu Mar 29, 2012 9:15 pm
Monkey seat??
There are two things in this world that take no skill: 1. Spending other people’s money and 2. Dismissing an idea.
strad
Post Thu Mar 29, 2012 9:19 pm
strad wrote:Monkey seat??
The little miniature wing sitting on the middle of the beam wing. :)
Crucial_Xtreme
Post Fri Mar 30, 2012 12:55 am
Ah...Thank You
strad
Post Fri Mar 30, 2012 1:56 am
Monkey seat is by far my new favorite aero phrase.
Grip is a four letter word.
2 is the new #1.
Jersey Tom
PreviousNext
Return to Formula One cars
Who is online
Users browsing this forum: gary123, Google Adsense [Bot], kentech and 18 guests
