Mercedes AMG F1 W03
Post Thu May 10, 2012 8:34 pm
radosav wrote:That's odd! The pic is of the front right, but it appears to have a reverse thread. Is that normal?
it has to rotate in the same way as wheel[/quote]
It is still odd. It is opposite to the knock offs that i have on two of my cars! Off side has reverse thread, not near side.
gilgen
Post Thu May 10, 2012 10:46 pm
Next they will be installing a rocking chair for the 'old' man.
Brian
hardingfv32
Post Thu May 10, 2012 11:22 pm
n_anirudh wrote:Scarbs just tweeted this:
Aren't those carbon parts the turning vanes. Or am I looking at the wrong thing?
Owen.C93
Post Fri May 11, 2012 12:09 am
These?
Seems a strange alignment?
Edit: Got it.
I was racing I was faster I passed him I won
Gridlock
Post Fri May 11, 2012 12:33 am
So front and rear wings are blown. As suspected and concluded way back in March.
Also you can see from the photo's that Morteza kindly put up that the most the air goes into and through the cockpit, to circumvent the law regarding the application of blown wings.
To me, this car would be an absolute nightmare to set up around a high downforce track like Barcelona for example.
The variance of pressures front and back, DRS on or off, high corner speeds etc must be tremendous. Others may copy this idea, but I doubt they will get both working in tandem as well as Mercedes have.
More could have been done.
David Purley
JohnsonsEvilTwin
Post Fri May 11, 2012 1:15 am
JohnsonsEvilTwin wrote:So front and rear wings are blown. As suspected and concluded way back in March.
What makes you say that?
Owen.C93
Post Fri May 11, 2012 1:27 am
Owen.C93 wrote:What makes you say that?
The rear DRS slot which was much fought over by Lotus and to a lesser extent Red Bull.
And the slots under the front wing which are in some part related to the twin pipes you see in the aforementioned pictures.
When the DRS is activate the rear wing is also blown allied to the front.
How do they set this thing up!?
Possibly Mercury suspension....
David Purley
JohnsonsEvilTwin
Post Fri May 11, 2012 1:46 am
It's been known for quite some now that the front wing is blown. However, I don't think we've seen anything yet that might indicate the rear wing is blown, too.
I still think the DRS slots just serve to activate and deactivate the system.
bhallg2k
Post Fri May 11, 2012 9:47 am
It is still odd. It is opposite to the knock offs that i have on two of my cars! Off side has reverse thread, not near side.[/quote]
The rotation depends on whether the "seat" ( i.e where the nut is seated against the wheel ) is concave or convex
IIRC- Lotus Elan vs Jag XK or E types
lotus7
Post Fri May 11, 2012 11:15 am
gilgen wrote:
FrukostScones wrote:Image
Actually, judging by the brake cooling dict, it's front left IMHO.
Spa 2012
Dragonfly
Post Fri May 11, 2012 12:55 pm
Gridlock
Post Fri May 11, 2012 1:06 pm
That almost makes it look like the Daffy Duct could be fed from air drawn in by the sidepods or even the exhaust.
bhallg2k
Post Fri May 11, 2012 3:49 pm
Apologies, I did mean to say left, and that is why I was puzzled.
gilgen
Post Fri May 11, 2012 4:01 pm
The overall times when looked at during actual sim time suggests Mercedes is about 1 second off the McLaren for pure race pace.
The fuel load variance could also be a factor as Mercedes will want to have tested Tyre degradation to its maximum...meaning running fatter around Barca.
There was clearly some work going on with all the antennae connected to Both W03 cars, but especially Schumacher's.
There has been some tinkering around the rear and the diffuser, I cannot find the pics, but will post it once I can find an unwatermarked copy.
The suspension component materials also look to have changed around the rear, Mercedes obviously trying to shift some mass away from the rear, to protect its tyres.
Ahh found one...
Also remarkable that Mercedes do not have the de rigour rear tail skirts as found on Most front running teams cars.
Compared to McLaren.
David Purley
JohnsonsEvilTwin
Post Fri May 11, 2012 4:05 pm
No monkey seat today either......
Ferraripilot
PreviousNext
Return to Formula One cars
Who is online
Users browsing this forum: Google Adsense [Bot], kwanchepan and 22 guests
