Ferrari F2012
Post Wed May 23, 2012 9:29 pm
Gridlock wrote:The last 10cm is a straight circular pipe with a 90deg straight flat cut at the end.
But do the regulations specify a certain diameter for the exhaust pipe? (I have no idea.)
Back pressure adjustments are easily made by simple adjustments to pipe diameter.
bhallg2k
147
Post Wed May 23, 2012 9:37 pm
There's a defined aperture size, yes, but it's quoted as a combined figure for exit area across both exhausts and I can't be arced to look it up, it works out to about 12cm diameter from memory.
I was racing I was faster I passed him I won
Gridlock
Post Wed May 23, 2012 9:38 pm
alogoc wrote:when driver releases the throttle does the gases from the collector have any speed to benefit downforce?
what makes the gases go out? negative pressure? vacuum?
Think of it as collected volume under pressure.
On-throttle exhaust gasses fills the chamber as they're being ejected from the exhaust pipes. Once the chamber is full, the exhaust gasses maintain pressure in the chamber. When the driver goes off-throttle, the collected volume is released due to the release of pressure within the exhaust. The release from the chamber provides added exhaust volume to off-throttle blowing.
The effect is not massive. It just helps to stabilize the transition.
EDIT:
Gridlock wrote:There's a defined aperture size, yes, but it's quoted as a combined figure for exit area across both exhausts and I can't be arced to look it up, it works out to about 12cm diameter from memory.
Are teams forbidden from adjusting the diameter anywhere along the length of exhaust? A simple pinch somewhere is all that's needed to adjust back pressure.
bhallg2k
147
Post Wed May 23, 2012 9:42 pm
The pressure differential will pull it out, yes. In principle I don't think it's doing much useful mid-corner gas ejection, it's more to smooth the transition from on- to off-throttle rear df levels. IE it turns a near-cliff edge graph into a more graceful slope. Off the top of my head this would allow a more sudden throttle body closing map (ECU controlled don't forget) which will aid engine braking more than slowly closing it to keep gas flowing.
Between the engine and the last 10cm, as far as I can tell, do what you want as long as there's no openings. I'm fascinated by the variety in manifold shapes given the stability of engine regs for 5 years and the near-identical fairing shapes and exhaust exit locations.
Gridlock
Post Wed May 23, 2012 9:52 pm
Gridlock wrote:I'm fascinated by the variety in manifold shapes given the stability of engine regs for 5 years and the near-identical fairing shapes and exhaust exit locations.
Better not repeat that, lest the powers-that-be narrow down those regulations, too. :lol:
bhallg2k
147
Post Wed May 23, 2012 10:29 pm
The exhaust branch is there to change the operating range of the tuned exhaust. I would say they are simply lengthening the exhaust system but without the packaging issues that would create.
Brian
hardingfv32
Post Wed May 23, 2012 11:08 pm
No, it's definitely about stabilizing the abrupt loss of downforce when going off-throttle. I read about it here last year.
bhallg2k
147
Post Thu May 24, 2012 12:41 am
Nope that is not why it is there. It is there to help the engine make more power at the designed RPM.
BMW used to do this in the E30 M3 back in the late 1980's. I don't remember what racing series though.
But anyway it is done for engine power characteristics. Whether it be low down power etc.
"I was blessed with the ability to understand how cars move," he explains. "You know how in 'The Matrix,' he can see the matrix? When I'm driving, I see the lines."
n smikle
Post Thu May 24, 2012 12:59 am
How does it help engine power characteristics?
bhallg2k
147
Post Thu May 24, 2012 1:05 am
It will have a resonance which you can tune to help reduce resistance in the pipe at certain RPMs.
Owen.C93
Post Thu May 24, 2012 1:56 am
But how? I looked up Heimholtz resonance, which is what I assume we're talking about, and I don't see how tuning that phenomenon would reduce resistance. If anything, it adds resistance due to the fluctuations inherent to harnessing it.
Wouldn't it make more sense to just redesign the header for this purpose?
I don't mean to seem incredulous, I'm just not understanding the concept as it's been presented.
bhallg2k
147
Post Thu May 24, 2012 2:53 am
Still trying to look for the header as I remember it years ago when i saw it on the internet, but this is closest I have come.
http://commons.wikimedia.org/wiki/File: ... 935%29.jpg
n smikle
Post Thu May 24, 2012 3:36 am
bhallg2k wrote:Wouldn't it make more sense to just redesign the header for this purpose?
Absolutely, if you have the space. I assume that the exhaust outlet location has a desired fixed location. This would be a way to change the engine output curve without too much packaging drama.
This is not about creating less resistance. It is about changing the tuning wave form location or the wave form peaks. Heimholtz resonance is on point.
Brian
hardingfv32
Post Thu May 24, 2012 4:43 am
Please take exhaust discussion here from now on:
:arrow: Helmholtz Exhaust - as seen on Ferrari F150/F2012
Whether any previous posts from here will be moved there is yet to be seen.
All posts after this one were talking about the car's performance in Monaco so they were moved there.
Join the chatroom during GP weekends!
mx_tifoso
Post Thu May 24, 2012 9:52 am
Monaco Front Bulkhead Detail
Front Brake Ducts
RW- No V-Groove/ No straight louvers
Flo-Vis Monakey Seat
Last edited by Crucial_Xtreme on Thu May 24, 2012 2:08 pm, edited 4 times in total.
Crucial_Xtreme
69
PreviousNext
Return to Formula One cars
Who is online
Users browsing this forum: beelsebob, F1NAC, Google [Bot], kwanchepan, sink, vlado09, zac510 and 20 guests
