Ferrari F2012
bhall
bhall
244
Re: Ferrari F2012
There there, they're there.
wrcsti
wrcsti
Re: Ferrari F2012
Only difference are the mirrors. And im sure hamilton likes that
CmdrVOODOO
Re: Ferrari F2012
italian wrote:Today we have seen two different configurations for the mirrors:
Massa:
[img]http://i.imgur.com/nsmaM.png[img]
Alonso:
[img]http://i.imgur.com/tje6Z.jpg[img]
The difference is obvious; the taller mirrors work better for checking who may be lapping you, while the wider mirrors work better if you're on the lead lap and are check to see who it was you just passed.
Reason: disabled img tags. no need to quote the large images so often
nhojekim1223
nhojekim1223
Re: Ferrari F2012
Massa:
Alonso:
Could be the angle, but in those pics it seems Massa is not using the additional cooling openings in the sidepods, which Fernando is using...
Massa is using also cooling openings at the side pods. The only difference is the height of the openings. In Massa's car the openings is uniform while in Alonso's its ascending. (judging from the pics)
Owen.C93
Owen.C93
191
Re: Ferrari F2012
That's just the angle.
Nando
Nando
Re: Ferrari F2012
Same cooling, different height on mirrors.
alogoc
alogoc
-10
Re: Ferrari F2012
THE F2012!
THE CAR THAN WON 2012 WORLD F1 CHAMPIONSHIP WHIT A TILTED ENGINE!
.poz
.poz
53
Re: Ferrari F2012
wrcsti wrote:Only difference are the mirrors. And im sure hamilton likes that
The fins under the nose are different too. Alonso is using the classical Ferrari L shaped, Massa the curved RB style ones
Nando
Nando
Re: Ferrari F2012
Could be the track not feeding the diffuser enough air so they have to lower it to optimize it?
f1316
89
Re: Ferrari F2012
And surely it's also a case of Ferrari wanting to raise the front height in order to better ride the curbs in Monaco. Obviously if the front is raised then the rear would have to be ridiculously high to maintain the rake.
raymondu999
Re: Ferrari F2012
It's likely that their mechanical setup for Monaco with the various spings and ARBs mean it has to run that way too.
失败者找理由,成功者找方法
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F2012
alogoc wrote:
Ferrari decides to abandon high rear rake philosophy!?
The F2012 is still running rake. I will post better picture after work.
FrukostScones
Re: Ferrari F2012
Neno
Neno
-29
Re: Ferrari F2012
you calling that a aero rake, only because Monaco is track with many bumps car have this rake. if you compare their rake with lotus or mclaren you will see it's almost insignificant. sure, maybe i'm wrong...
italian
italian
Re: Ferrari F2012
Video of the changes on the F2012 for the Monaco GP: http://www.omnicorse.it/video/238/la-fe ... montecarlo
"Two things are infinite: the universe and human stupidity, but about the universe I still have some doubts." Albert Einstein
