Mercedes AMG F1 W03
Post Sat Jun 02, 2012 2:18 am
ForMuLaOne wrote:I guess i am not the only one who noticed that the MGP W03 was the only car which drove easily over the bump in Monaco, i think it`s somewhere around Mirabeu. They also did this with full fuel load in the race. So, although Scarbs mentioned that the suspension technology they are meant to race with is something that had been used by other teams for some years now, the MGP W03 seems to have some tweaks on it. The moment i am talking about is also mentioned in this Sky footage.
http://www.youtube.com/watch?v=3-QdCMkd ... re=related
We also did not see any lock ups in the bumpy areas of the track, something i saw a lot at Sauber`s cars for example. So, there has to be something special about the car`s suspension, as the difference is signifcant.
Yeah that is how Schumacher got pole... he sorta "cheated" half a second by doing that alone. A very clever guy.
"I was blessed with the ability to understand how cars move," he explains. "You know how in 'The Matrix,' he can see the matrix? When I'm driving, I see the lines."
n smikle
Post Sat Jun 02, 2012 10:19 am
so we don´t call it mercury ..but that car has impressive suspension .Mind you only two years ago W01 was one of the worst cars in the suspension area methinks.
marcush.
Post Sat Jun 02, 2012 2:12 pm
The Mercedes has been very softly sprung in the front compared to others this year. Going that direction makes sense (but maybe not regarding how extreme it is) given both drivers' driving style.
Renault typically had been typically good mechanically. Maybe Bob had something to do with that.
vinuneuro
Post Sat Jun 02, 2012 3:43 pm
n smikle wrote:Yeah that is how Schumacher got pole... he sorta "cheated" half a second by doing that alone. A very clever guy.
Only problem is that the bump is in Sector 1 and he got most of his time in Sector 2 :roll:
Ganxxta
Post Sat Jun 02, 2012 6:03 pm
I very much doubt he gained half a second by not going around the bump.
"You're so angry that you throw your gloves down, and the worst part is; you have to pick them up again." - Steve Matchett
Patiently waiting...
scuderiafan
Post Sat Jun 02, 2012 9:46 pm
It's the characteristic I was alluding to earlier. The DDRS sheds downforce from the front wing allowing the WO3 to run lower front ride height and/or softer front suspension. This allows them to ride the curbs a little better than the rest of the field. I seem to recall a time when "ability to ride the curbs" was discussed at length and used as a performance differentiator but I'm unable to dig it up.
However, while the DDRS may explain performance characteristics of the front end, it does not explain why the WO3 is so good on corner exit. The W02 had similarly good traction characteristics out of corners (see Schumacher in Canada and Monza). Although not unique to Mercedes, it stands to reason interlinked suspension setups should play a part in this, mercury discussion aside.
JMN
Post Sat Jun 02, 2012 9:56 pm
JMN wrote:It's the characteristic I was alluding to earlier. The DDRS sheds downforce from the front wing allowing the WO3 to run lower front ride height and/or softer front suspension. This allows them to ride the curbs a little better than the rest of the field. I seem to recall a time when "ability to ride the curbs" was discussed at length and used as a performance differentiator but I'm unable to dig it up.
The ddrs can only be used in quali, so your argument makes no sense. See the specific thread on this matter.
gilgen
Post Sun Jun 03, 2012 7:52 am
The DDRS can be used anytime you use DRS not just Quali.
Huntresa
Post Sun Jun 03, 2012 9:47 am
Of course it can, but in a race, the Merc has to be within 1 second of a car in front, and trying to pass. That rarely happens, and the discussion was about the handling of the car on the twisty bits, where DRS would never be in use, even in quali! :lol: :lol: :lol:
gilgen
Post Sun Jun 03, 2012 9:49 am
DDRS can be used anytime but it's only useful in quali.
Ozan
Post Sun Jun 03, 2012 2:15 pm
Maybe we should distinguish between DDRS and frontwing F-duct.
DDRS is indirectly operated by DRS-button/pedal. The slots which are hidden by the DRS-flap in its down position are only opened during the activation of the DRS-flap by button/pedal.
Frontwing F-duct/slots on the underside of the frontwing which also might work actively together with DDRS, (or not/are bypassed during DDRS-activation ) and could also act passively whithout DRS-activation under certain circumstances.
"Results never tell the full picture. You need to take a close look at the story behind those results." raymondu999
FrukostScones
Post Sun Jun 03, 2012 3:50 pm
Same thing. That is the end of sector one going into sector Two. It gave him a better run into the Hairpin.
n smikle
Post Sun Jun 03, 2012 3:52 pm
They had monster traction in the first Korean GP too.
n smikle
Post Sun Jun 03, 2012 11:45 pm
There are some good points here. However, although you can use DRS anywhere in qualifying, you must keep your qualifying setup into the race, where you are not allowed to do so. I don't think it really lets them run softer suspension or ride height than other teams, though they may opt to do so anyways. Note that softer springs generally require taller ride heights to prevent bottoming out or excess skidplank wear. Monaco generally requires taller ride heights anyways, though.
If they are running relatively soft springs, it would also explain their good low speed traction. But I don't know if they have good low speed traction in race, I haven't been able to watch most of the races this year. I suspect that its just a matter of setup.
Lycoming
Post Mon Jun 04, 2012 1:47 pm
FrukostScones wrote:Frontwing F-duct/slots on the underside of the frontwing which also might work actively together with DDRS, (or not/are bypassed during DDRS-activation ) and could also act passively whithout DRS-activation under certain circumstances.
Using the occasionally-appearing flat rectangular silver secondary scoop on the top of the bulkhead?
I was racing I was faster I passed him I won
Gridlock
PreviousNext
Return to Formula One cars
Who is online
Users browsing this forum: kwanchepan, mgeary, Pierce89, Twitter [Bot] and 15 guests
