Toro Rosso STR8 Ferrari
Post Sat Feb 02, 2013 12:12 pm
Thread will be unlocked when the car is launched ... Monday 4th February @ 1700 GMT
http://www.tororosso.com
VoiTube Channel http://www.youtube.com/channel/HCXqwkHvQ1nrU
(Thanks to Gridlock for links)
Pre-launch speculation thread :arrow: viewtopic.php?f=12&t=14447
richard_leeds
Post Mon Feb 04, 2013 5:50 pm
bucker
Post Mon Feb 04, 2013 5:51 pm
balalev
Post Mon Feb 04, 2013 5:54 pm
Owen.C93
Post Mon Feb 04, 2013 5:58 pm
The modesty panel fitting is something appaling...
Reason: Removed quoted post right above
"Mi chiedete quale è la differenza tra la F1 eroica e quella attuale. Beh, è come se prima si camminasse in equilibrio su un filo sospeso a strapiombo sul Grand Canyon. Ora quel filo è ben teso in camera da letto, a un palmo dal materasso: l'abilità richiesta per camminarci sopra è la stessa, ma la sfida è cambiata per sempre".
- Stirling Moss -
"Se gommo tiene, io vince gara! Se gommo non tiene, io come bomba dentro montagna."
- Markku Alen -
Matt89
Post Mon Feb 04, 2013 5:59 pm
looks like the STR7 but with different nose and traditional sidepods
astracrazy
Post Mon Feb 04, 2013 6:01 pm
Yeah no more MASSSIVE undercut sidepods but still undercut quite alot, but srsly they rly need to fukkn get a new Fw this year!
Huntresa
you can see the lines of the modesty panel nicely...
"Results never tell the full picture. You need to take a close look at the story behind those results." raymondu999
FrukostScones
Post Mon Feb 04, 2013 6:03 pm
Scoopless front brake ducts:
via Racecar Engineering http://www.racecar-engineering.com/news ... kes-debut/
techF1LES
Post Mon Feb 04, 2013 6:04 pm
Either there is some technology being shared between the two RB teams or STR simply carbon copied the front wing philosophy RBR uses.
But which directs airflow to a completely different body.
Nando
Post Mon Feb 04, 2013 6:08 pm
Nando wrote:Either there is some technology being shared between the two RB teams or STR simply carbon copied the front wing philosophy RBR uses.
This is the same FW from the last 2 seasons, nothing like RB that updates every other race almost :P
Huntresa
Post Mon Feb 04, 2013 6:10 pm
It´s undoubtedly a very similar wing,
Nando
Post Mon Feb 04, 2013 6:11 pm
Nando wrote:It´s undoubtedly a very similar wing,
The wing on this launch is 90% the exact same as last years launch wing, the change is what came during 2012 season.
And endplates stem from STR6
Huntresa
A very interesting big 'r' shaped vane on the floor near the tire
+ enclosed drive shaft
Post Mon Feb 04, 2013 6:14 pm
Any rear shots? On first glance - different sidepods, modesty panel, front brake ducts, camera pods mounted between FW pylons + they've gone for gold/bronze wheels this time.
I stand out because I'm outstanding. If you can't stand it, sit down, then!
Predator
Next
Return to Formula One cars
Who is online
Users browsing this forum: hakan439, kwanchepan, Peetbeat, Sevach and 16 guests
