Don't get me started on track limits hypocrisy
. You'd think last season's bankruptcy of decency of applying the rules should still be biting FIA in the a... but it's shameless "about the corners". Let me give you this handy C. Whiting's "corners" guide for 2014:
Hungary - Gro-Mass (whichever, 4th) corner - bad
Singapore - Hulk-Per corner - bad
Suzuka - Ricc-... corner - bad
India (?) (or wherever) - Hul- Bott - surprisingly - OK
Abu Dhabi - Alon-Verg - all rules thrown away - OK
Brazil - Massa - huge controversy but - bad
In true F1 fashion when everything stands on its head the closest, first and the most controversial case, 10 cm for split second wasn't controversial at all, 4 wheels off - penalty no doubt about it. All other were discussed as if there was anything to discuss about them after that, especially Abu Dhabi. So no 1. not every incident is different, 2. there were closest possible penalised, and blatant ones that weren't.
Instead of dealing with it properly like comment on every situation or admit to mistakes their usual conduct is to weasel themselves out with fake explanation that it's all about corners and every incident is "different". Even in NBA where you pay to state opinion they learned to explain bad calls, they say openly this situation was a foul and call was wrong.
Imagine something like that in F1, it would force them to be consistent no matter which team/driver is involved and they wouldn't want that.
