Lotus E22 Renault
jagunx51
185
Re: Lotus E22 Renault
He's got the the Maldo's touch.
China 2014 - Friday (18.04.2014)
Do you have the Maldonado version of this pic? I found smaller ones and I made a comparison; they are running different front wings, nose and floor. But pics with higher Res show them better obviously.
stefan_ wrote:China 2014 - Friday (18.04.2014)
http://i.imgur.com/kQXYWvL.jpg
AnthonyG
38
Can you point out some differences?
I only see grosjean running more front wing and judging by the decal a slightly shorter tusk nose for Maldonado.
Interesting.
There is many other small differences. Could be a nice ''spot the difference'' game : P
And the bottom part of the monocoque, under the 'Clear' sticker looks different to me on Mal's car :!:
emmepi27
emmepi27
141
My old pic about the front wings differeces: :wink: (but i think in China GP only the main plane is different)
Okay. Thx.
iotar__
Fairly obvious for a long time third grade engine support and units:
http://translate.google.com/translate?h ... 12910.html
I don't how precise this is but let's say "it's reaching" 30 hp. Too little too late to talk about it now after endless "special partnership" claims.
So according to Permane and AMuS
-aero is more stable now
-windtunnel data corelation is better
-they worked on the settings for the first time yesterday
-RBR and STR get new engine updates first
-Lotus even got old PU parts in Bahrain testing days (old Kers+old engine)
-That's because of Renault's smaller budget (50%less than Merc says AMuS)
-less power for Lotus (30hp)
-In Spain they should get the same engines as RBR
New FW (top)
zack!
zack!
Blackout wrote:Do you have the Maldonado version of this pic? I found smaller ones and I made a comparison; they are running different front wings, nose and floor. But pics with higher Res show them better obviously.
http://www.servimg.com/image_preview.ph ... u=14795526
This rear wing looks bizarre to me, the "attack" seems too high.
In second thought, when I compare to aeroplane wing shape and lift force, and then reverse the figure I understand this also gives some down force with bottom part of airflow, and probably avoiding some drag penalty. I don't know how to explain that (not easy for a non aerodynamicist not english speaker), but less effect of airflow striking an uplifted surface, and more effect on airflow passing under the wing and being accelerate compare the one above, generating under pressured zone below the wing (reverse lift force).
But well, still bizarre. Any other team being such extreme with attack angle of the rear wing ?
EDIT : sorry alredy discussed before in the thread, here :
http://www.f1technical.net/forum/viewto ... 76#p501376
Looks like they made some changes under the bpdywork. The intercooler's water rad is now inline with the bigger (oil?) rad and it's bigger.
China
Malaysia
Owen.C93
Owen.C93
171
If that's the Oil rad then maybe it was taken off with the engine as I believe they took it apart to fix an oil leak in the first place.
I think the Sepang small rad is the intercooler's water radiator, not an oil rad.
