That's a very excellend post there - in fact you beat me to the points about the definition of luck. I was going to write the same thing, more or less. Nothing really much to add there.
If you want to nullfy the element of luck where tge drivers are concerned, might as well have them build their oen car using their own organised/built materials. Then they can be held fully respobsible and in control of what they race and what failures they receive.
Since this isnt what it is, motorsport is still very much a team effort. Win as/with the team, fail with them.
There are some arguments that Lewis could be heavier on his car/equipment because he's an agressive driver (opposed to the likes of say Button who are known to be smooth drivers). That may be true, and it may be also true that because of that, that he gets his increased share of failures. I however dont see how you could put that blame or responsibility on him - after all, as a team and especially in todays F1, the team has hundreds of sensors and computers to monitor and simulate everything on the car. If a driver is using the car beyond its intended scope and limits, it should show up eventually and its the teams respobsibility to inform their driver.
We've had various cases of this being highlighted on race weekends - a quick glance at the team radio is sufficient. One example that springs to my mind was i think P3 in Hubgary when Nico was adviced to use a different gear in a particular corner to put less strain on his engine.
These things are crucial and absolutely necessary. The driver relies on the team doing its job properly and to the best of their ability. Up to that point, it's absolutely the drivers job to maximize what ever he can out of his car to be as close to that limit as possible. After all F1 is about finding limits - as a team and as a driver.
Want more driver influence without 'the luck' (from his POV)? Easy: start with reducing the extensive monitoring of the cars and seize all communication while they race. Let them drive dark. This still wouldnt avoid unlucky failures, but as drivers they would need to rely less on team information and drive more cautiously. Or as i said above; let them build their own cars too.
If we do statistics to analyze if Hamilton suffers more failures, it would also be nice to include some sort of nunbers how much potential points those failure cost and perhaps if they realistically were avoidable or just unfortunate circumstances.
Edit: sorry for all the typos. I actually typed this up while sitting at the pool using the 5inch display of my HTC. Yeah, i should get a life, i know...
