Williams FW37 Mercedes Speculation Thread
Re: Williams FW37 Mercedes Speculation Thread
I like that nose concept. It only seems simple, but what separates it from some of the concepts we have seen so far is that the nose is pushed forward ahead of the wing, which preserves a very high "under belly" while still maintaining the low nose tip in the regulated area.
☄️ Myth of the five suns. ☄️
LxVxFxHxN
LookBackTime
LookBackTime
472
First pictures of Williams FW37 will be shown in F1 Racing, which will be released on the January, 22nd.
Are you sure? they did that last year...
Blanchimont
Blanchimont
214
They'll probably repeat it!
https://twitter.com/F1Racing_mag/status ... 6318078976 https://twitter.com/F1Racing_mag/status ... 2477817856 Edit: Here we go, online since Jan 16th!!! How could the internet miss that?
https://twitter.com/ReadlyUK/status/556150181608325122
Waiting for the "t's only a CGI"-comment
Dear FIA, if you read this, please pm me for a redesign of the Technical Regulations to avoid finger nose shapes for 2016! :-)
FrukostScones
162
nice front wing and front brake ducts...
tomazy
tomazy
205
Hmmm, apart from the nose and smaller sidepods, I dont see any major difirences (witch is good i would guess). Front brake ducts are a bit diffirent, similar to FW35 ones with blown wheel nuts.
An 'M' shaped second cross section :?: (inverted U + T) ?
Or is it just just a 'T'...
FrukostScones
162
Blackout wrote:An 'M' shaped second cross section :?: (inverted U + T) ?
just a T me thinks
Timstr
Timstr
I think I'm seeing mercedes W05 style front lower wishbones.
KingHamilton01
still ugly when it comes to the nose, other team's will come up with better solution's!
McLaren Mercedes
Huge dissapointment for the ladies after last years 'appendage'......looks like the williams took a cold shower.
anyway, that's really ugly. Williams had one of the best looking cars last season, this could be one of the ugliest.
looks a bit like an interpretation of last year's Mclaren.
Disappointed, really, expected better from Williams. Assuming this really is the real deal.
McMrocks
McMrocks
32
It's not their job to create a beautiful car. It's their job to build a fast one. Form follows function, etc.
This year we may see even less variety than last year. But this is what happens if you tighten the rules.
Timstr wrote:I think I'm seeing mercedes W05 style front lower wishbones.
Indeed, it looks like they've combined the two lower wishbones all the way to the chassis.
edit: Nope, they didn't
Remarkable sharp edges at the upper edge of the nose tip. I guess they had to flatten it to stay below the maximum height.
tomazy
tomazy
205
I think that it has a standard front suspention. Look at the front right suspention, you can see that the lower wishbone has two parts, just that the front one is larger.
triptube
triptube
Personally, I have, I also imagined what beautiful or desirable in the nose area! But Pat Symonds, had already announced that what would come to circumvent the requirements of the FIA!
McMrocks
McMrocks
32
tomazy wrote:I think that it has a standard front suspention. Look at the front right suspention, you can see that the lower wishbone has two parts, just that the front one is larger.
Yep, you're right. I was wrong. It was almost invisible on the front left corner
