Williams FW37 Mercedes
n_anirudh
n_anirudh
Re: Williams FW37 Mercedes
http://en.f1i.com/news/22949-red-bull-t ... -hand.html
Team principal Christian Horner likened Red Bull’s rear wing level at Spa-Francorchamps to the low-downforce Monza-spec all teams will use in Italy, while saying Williams was running what would be close to Monaco levels of wing.
Last time I saw that was HRT running monaco wings in monza. Is the team is financial trouble?
That's in all honesty a way too quick jump to finances. Williams is financially quite healthy; rather they preferred more downforce to keep up in the corners.
227
not sure if pointed out already, but see the bat ears on the diffuser lip?
Introduced in Austria i think, it's has been noticed before but no extended breakdown on it.
It is a fancy air dam for the diffuser that also creates two vortices.
LookBackTime
LookBackTime
472
Albert Fabrega ES - Monza
Via @Albrodpul
LookBackTime
LookBackTime
472
LookBackTime
LookBackTime
472
Craig Scarborough ‏@ScarbsF1
Williams newer spec FW flattened so much there's a gap by the adjuster!
LookBackTime
LookBackTime
472
Valtteri's new Monza race tyres?
SiLo
134
Interesting way to reduce drag on the wing there. Rather than run a much shallower wing, they just lopped the top off it and reduced the height.
Felipe Baby!
LookBackTime
LookBackTime
472
Albert Fabrega ES ‏@AlbertFabrega Monza, Lombardia
El Williams en Monza.
fw37
fw37
Hello, how are you
fw37
fw37
I hope that the car be fast in Monza ،، For I heard that Mercedes used a new engine using the remaining 7 Tochen // [-o<
fw37
fw37
Question? Is the Mercedes will give Williams the new engine in Monza ؟
