modbaraban wrote:Oh I never thought of that. Really wierd cos there was a combo of BBS+Bridgestone.
BAR Honda used BBS+Michelin combo in 2005.
ds.raikkonen wrote:modbaraban wrote:Oh I never thought of that. Really wierd cos there was a combo of BBS+Bridgestone.
modbaraban wrote:Toyota (TF103)
Q: How does an air spring differ from a coil spring?
A: The visual difference is obvious. The operating principles are different. One produces a spring force by stressing a steel rod, while the other produces the same force by compressing a trapped volume of air. Functionally, there is no difference. The vehicle chassis only interacts with a spring force. It doesn't care whether that force originates from a steel spring or from an air spring. The airspring is different because we can control its properties. We can change its height (and the height of the vehicle) by controlling the pressure within the air spring. We can also change the spring rate in a dual-rate system by altering the volume of air contained inside the spring. To accomplish the same feat with a coil spring requires changing parts: more parts = more time = more money.
ginsu wrote:That's why I put that quote, noting that an increase in air volume affects the spring rate of the tire (and probably also the damping). This means that BMW would effectively be running a more compliant, more forgiving tire then all the other teams.
If you don't think there's a benefit to that, then you don't know what makes a car fast.
Well, because the aero loads define the minimum ride height allowable and softening the suspension spring rate will cause the car to bottom out which could lead to a loss of control. I'm pretty sure that the tire's spring rate doesn't have as direct an effect on the ride height (although, it does have some).
I tell you one reason why I suspect this is of large benefit is that I've done some back to back comparisons of low-profile tires vs standard tires and there is a significant difference in drivability. Yes, carcass construction does have a part in it, but I think the big difference was in air volume.
DaveKillens wrote:Additionally, if the spokes are hollow, then there would be more wheel surface in contact with the gas. That would lead to improved cooling of the wheel/tire assembly.
Jersey Tom wrote:
Nope. They both have just as much effect. You are correct in the respect that the suspension itself won't bottom out, but if the tire rate goes down it will squash more under load and the car ride height will drop, and the chassis will bottom. Not good!
Jersey Tom wrote:
Other way around. Commonly accepted that sidewall stiffness is a big link to handling. Low profile = shorter sidewall. Think of it as a beam deflection problem. Shorter length will be effectively stiffer.
Air pressure is going to also have a big effect on how much rubber you have on the road and on steering feel.. but not so much volume.
Users browsing this forum: AddThis [Crawler], F1PuertoRico and 5 guests
