Aston Martin wants hyper-car to be faster than F1 cars
Bonker T
Bonker T
Re: Aston Martin wants hyper-car to be faster than F1 cars
In the record run the Nio seems to be on full slicks though, which is a big advantage.
Phil
66
@Andres
Yeah, it probably does. I just thought it had some merit in here since there was a lot of discussion surrounding if it was technically possible to create a road 'hyper-car' that could be faster than an F1 car, and I think this car goes a long way in showing how such a [electric] car could be realized without the constraints that a normal ICE car has with piping, cooling etc.
I mean just look at that underbody and all those air channels. :shock:
#Team44 supporter
VARIANT | one
FW17 wrote:
16 May 2017, 16:30
So do you think the Aston Martin Redbull will beat this Chinese car
https://cnet3.cbsistatic.com/img/pT_zTF ... -ep9-1.jpg
https://www.youtube.com/watch?v=mcepG9Twa_8
If power-to-weight and downforce-to-weight ratios still mean anything, Valkyrie isn't going to have any issues. That electric thing is a pig... as electric cars tend to be.
SR71
VARIANT | one wrote:
19 May 2017, 09:50
FW17 wrote:
16 May 2017, 16:30
For now.
humble sabot
27
And a little while longer. Unless one of the more esoteric battery developments out there bear fruit in the car type application. Of course you could, if you wanted to do a record run, put in less battery weight since you don't need 200km of range.
It'll be interesting to see how they integrate the electric portion of this project. The AMG one is a copy of the F1 format plus front wheel motors, but this will almost certainly remain rear drive to keep the aero design under the nose. P1-style?
the four immutable forces:
static balance
dynamic balance
static imbalance
dynamic imbalance
Whilst batteries are heavy, they have the benefit of being able to be packaged low down in the car. This at least helps handling etc. An ICE is always going to be a big lump in one location, batteries can be placed around the car if necessary to optimise weight distribution.
Electric makes sense for low mileage cars like this. Let's face it, no one is every going to use one of these hypercars as a long range touring car anyway, so being limited to e.g. 100 miles is all they need. It lets them get out and show off to their friends before putting it back in the garage.
SR71
Valkyrie was on display in Monaco. A lot of blog focus has been on the apperance of some headlights but what stood out to me was open fenders and covered wheels. Looks like production surfaces and part lines are showing up. Original design intent is being kept alive so far.
Love those covered wheels - reminds me of some vintage LMP Porsche details.
roon
roon
412
Might this project partly explain RB's minimalist development path in F1 this season?
The wheel vent is interesting, how it vents above and below the door. The shape mimics the taillights & engine vents on their other cars. The wheel covers look sealed--I'm not seeing any gap at the rim. Brake heat vented inboard?
humble sabot
27
couple more shots here: https://www.motor1.com/news/148433/asto ... ed-monaco/
and here: https://www.instagram.com/bogdancapusan/
They've significantly opened up the ventilation at the rear as well.
And moved the exhaust exit further back.
Also seems to have sprouted a roof scoop.
static balance
dynamic balance
static imbalance
dynamic imbalance
roon
roon
412
Three flatscreens in the cockpit. I presume side & rearview camera displays.
F1NAC
164
shot from rear of Valkyrie
djos
113
F1NAC wrote:
15 Jun 2017, 17:27
https://scontent.fzag1-1.fna.fbcdn.net/ ... e=59D74F27
That diffuser is nothing short of epic! =D>
"In downforce we trust"
It's changed a bit in detail from the "bland" concept car originally showed to the press, unsurprisingly
humble sabot
27
It's interesting comparing those two shots. They added diffuser volume, so I guess they know their gearbox better; also looks like the wing is better placed to help diffuser extraction without that trailing edge in the way
static balance
dynamic balance
static imbalance
dynamic imbalance
humble sabot
27
some more from instagram:
https://www.instagram.com/p/BVX_gxfHoHt ... d=valkyrie
https://www.instagram.com/p/BVYBGwUgpVN ... ahernassar
Sorry they have different thumbnails but are the same clip. Not sure who should get credit.
There are definitely a lot of changes!
static balance
dynamic balance
static imbalance
dynamic imbalance
