Hello, here is my simple and humble sketch of the turbo singleseater for 2014.
In addition to the cone with the elephant-nose (which will be surely used by more than on team imho), the highlights are:
- since the radiators surfaces should increase of about 40% compared to 2013, i expect that there may be not only many un-conventional radiator schemes into the sidepods but also a separation of the air inlets ... here, one is very thin and almost horizontal (for intercoolers), the second one is larger and benefits from the air compression generated by the lower-surface of the upper intake bodywork (kind of a wing shape) [see detailed drawing below];
- the two vents in the area on the back of the driver's head side protections (for cooling ecu units or batteries);
- monkey seat: iI thought that it could be hung under the main profile of the rear wing, given that the side plates connected to the diffuser could be used as support of the wing itself; and possibly interact with the hot gases out from the exhaust...
- gills all-around the final section of side pods (slightly larger than in 2013), with a full-width concept based on Renault's in Alonso's WC years.
Feel free to comment.
