should DRS be banned in qualifying ?
Poll ended at Sat Oct 13, 2012 7:43 pm
yes
30%
outside the DRS zone
16%
no
54%
Total votes : 37
Post Wed Oct 03, 2012 3:19 pm
sorry if this has come up before , if so my search here missed it
as I understand it , DRS was authorised as an aid to overtaking ; I understand the need to 'practise' with it , but , as there is no overtaking in qualifying , why is it permitted ?
to the optimist a glass is half full ; to the pessimist a glass is half empty ; to the F1 engineer the glass is twice as big as it needs to be
lebesset
Post Wed Oct 03, 2012 3:21 pm
Because qualifying is a practice session.
beelsebob
70
Post Wed Oct 03, 2012 3:26 pm
As a gimmick to get the fastest possible lap time, along with near empty fuel tanks.
Otherwise it would only be enabled in the DRS zone as a true representation of race pace and teams would qualify on full fuel. That would be a more accurate representation of a car's pace at the start of the race. Isn't that meant to be purpose of qualification?
richard_leeds
Post Wed Oct 03, 2012 3:27 pm
ban the cars and make them have a race around the track on foot to decide the starting order
snoop1050
Post Wed Oct 03, 2012 4:01 pm
I belive that DRS should have limitations attached to it, make it less of a gimmick and more of a attack/defence tool in races and a device to be used tactically.
My DRS rules would be as follows:
* DRS Zones will be gone, when DRS is in use, anyone can use it after the first lap of the race, or first lap after a safety car or red flag restart. In effect the whole track is active as a DRS Zone.
* If DRS is used when steering input exceeds a 45 degree steering angle it will close, so that it cant be used arround high speed corners like 130R and Copse for instance.
* In FP1 and FP2 it should be used for the first 60 minuites of the session with the last 30 minuites being race prep
* In FP3 it shall remain closed for the first 15 minuites before being unlocked for use for Quali prep.
* In Qualifying, DRS shall be limited to 100 seconds covering the whole Q1, Q2 and Q3 session. This would make it posible for the 3 usual teams that we loose in Q1 to make it to Q2 as some drivers would be trying to make it into Q2 without using it.
* The race DRS rulle will be that all drivers will be given 3 times to the nearest 30 seconds to the pole time, so if the pole time is 80 seconds, all drivers get 250 seconds; if the pole time is 82 seconds all drivers get 300 seconds. This means that drivers can go into a "DRS Save" mode in the race as well, meaning they can use it early on to attack and then hold on at the end of the race or use it to banzai a 5 place increase in the last 3 laps on low fuel.
* In order to give the lower teams a incentive, there shall be 1 point on offer to the fastest driver that dosnt finish in the points. This point shall not be awarded in the constructors title however.
ESPImperium
27
Post Wed Oct 03, 2012 4:18 pm
YES!
What is the reason behind it to allow it in qualifying. It only consumes resources and teams with a better DRS but worse car can gain positions on the starting grid. Maybe Saubers and Lotus qualifying weakness is due to shitty DRS wing/open procedure.
Most of the time in the race the guys run with closed wings so why not in quali? The team can practise DRS in the DRS zone in free practise.
please include a poll.
"Results never tell the full picture. You need to take a close look at the story behind those results." raymondu999
FrukostScones
Post Wed Oct 03, 2012 4:19 pm
The original plan was not to use it in qualifying if I recall correctly. But the teams showed that if you setup a car without DRS to be fastest as possible in qualifiying, then in the race DRS will be useless because as soon as you open it you will hit the rev limiter and you won't gain any speed.
So the FIA reacted to this by letting it be used also in qualy.
Tim
Tim.Wright
55
Post Wed Oct 03, 2012 4:22 pm
Tim.Wright wrote:The original plan was not to use it in qualifying if I recall correctly. But the teams showed that if you setup a car without DRS to be fastest as possible in qualifiying, then in the race DRS will be useless because as soon as you open it you will hit the rev limiter and you won't gain any speed.
Tim
so why not limit its usage on the DRS zone?
I think the big teams knew that they would have an advantage because of $$$.
FrukostScones
Post Wed Oct 03, 2012 4:50 pm
I don't know the answer to that. Perhaps some more thought will reveal that too.
I only chimed in because I remembered there was a technical reason for it.
Tim
Tim.Wright
55
Post Wed Oct 03, 2012 5:03 pm
Qualifying is about man and machine and taking what you have in regulations and making it the fastest it can be.
Really the only thing that handicaps this is the ride-height, in Q3 they run their cars at the absolute highest level of the whole weekend.
which is the opposite of what Qualifying is about. So i think ride heights should be allowed to be changed in Parc Ferme.
Under heavy control from FIA of course.
During these times when there´s no OTBD or other gimmick that puts one team ahead i quite enjoy Qualifying, possibly even more then the race.
Like Q2, how many times haven´t we seen Top 13 separated by 1 second. To me that is fantastic.
Nando
Post Wed Oct 03, 2012 5:51 pm
Or we could just open the technical regulations and allow active aero among other things ... :twisted:
Slife
Post Wed Oct 03, 2012 6:06 pm
Tim
Because a single DRS zone would not be enough to justify its usage.
timbo
Post Wed Oct 03, 2012 6:12 pm
Love it in qualifying, makes the driver choose between downforce and speed, more driving skill, more top end speed (a 400 meters straight suffices to reach 300+ km/h most of the time) and cheap solution.
I am all for it (in qualifying).
Ogami musashi
Post Wed Oct 03, 2012 7:24 pm
Moot point as they are getting rid of DRS entirely are they not?...As they should imo
There are two things in this world that take no skill: 1. Spending other people’s money and 2. Dismissing an idea.
strad
67
Post Wed Oct 03, 2012 7:28 pm
strad wrote:Moot point as they are getting rid of DRS entirely are they not?...As they should imo
Not that i am aware of, maybe you confuse with Double drs which a set of systems designed at stalling the rear and/or front wing;
Ogami musashi
Next
Return to General chat
Who is online
Users browsing this forum: Baidu [Spider], sknguy, Yandex [Bot] and 5 guests
