Motorsport and Denis Jenkinson.
Scuderia_Russ
It seems some things never change. This made me smile this morning. In a retrospective look at some of the articles by Denis Jenkinson in the magazine Motorsport, this is what he had to say about the driver's job in 1969. Sounded very familiar.
During a recent discussion on grand prix drivers past and present, the inevitable Fangio,Moss, Clark,Stewart battle raged. It did not seem reasonable to compare Nazzaro in 1907 with Stewart in 1967 because the things the drivers had to do were so different.
With the Cosworth V8, Lucas introduced a limiter that can be set to any rpm; the driver of today can almost forgethis engine and can certainly drive as hard as it will go for the whole race. He can also virtually forget his gearbox: with six close ratios you just flick a small lever with finger and thumb: no need to grad a large knob on a long lever. Perhaps the biggest advance has been the disc brake: the driver of today can use his brakes as hard on the last lap of a GP as on the first. He can forget tyre wear too; there is no need to conserve tyres or stop for new ones. And grand prix races today only last two hours, so he does not need to be built like an all-in wrestler- witness Stewart or Ickx.
We began to wonder just what our driver of the today has to do. He can bearly break an engine, can't muff a gearchange, can't wear out his breaks or tyres, he just has to lay there and drive.
But while it is different, there is still a great deal to do, and the things which are unchanged are much more critical. Because so many cars have equal performance he has to make every movement to almost a millisecond accuracy. He still has to judge braking distances, but due to improved brakes and tyres he can brake later, at higher approach speeds. Because of better reliability he can race for the whole two hours, and often has to. He has to put more effort into the driving than yesterday's counterpart, with more concentration and keener judgement. The gp driver still does an outstanding job; it's just that he must apply his skills to different things.
"Whether you think you can or can't, either way you are right."
-Henry Ford-
Guest
Guest
\:D/
Cheers
Fx
RH1300S
RH1300S
Yes....good old Jenks. It's always great when some of his stuff gets re-born 8)
