Red Bull RB10 Pre-launch Speculation
Holm86
245
Re: Red Bull RB10 Pre-launch Speculation
kartwheels wrote:http://scarbsf1.com/blog1/2013/12/04/sp ... redcition/
just to throw a spanner in the works, here is some speculation from Germany, not sure how accurate this is? I thought there would be no monkey seats within the 2014 regs?
Do people ever look at the previous pages before posting??
Monkey seat is allowed. Its the beam wing that's gone.
Tim.Wright
330
Its also answered in the link he posted...
Gerhard Berger
Gerhard Berger
-1
FrukostScones wrote:http://translate.google.de/translate?sl ... 44005.html
if already posted?, didn't see it!
Newey on 2013 /2014 and RB10:
"The biggest problem is the front wing."
" I will try to keep the "rake" even without exhaust blowing"
something like this he says, so other common means than the exhaust to seal the diffuser or some sneaky sneaky stuff..?
Keeping the rake surely makes little sense without blowing the exhaust.
I think his answet to the last question is more "I've made cars in the past without EBDs, so i'll do what i did back then".
227
remember rake keeps the front wing lower as well.
timbo
timbo
111
ringo wrote:remember rake keeps the front wing lower as well.
which would shift aero balance forward. It's only good if you have enough rear DF.
raymondu999
Coefficient wrote:
Owen.C93 wrote:MP4-25 was probably the closest we've seen.
To what?
Ramp, sans coanda exhaust
失败者找理由,成功者找方法
gandharva
252
Gerhard Berger wrote: Keeping the rake surely makes little sense without blowing the exhaust.
Going for rake always makes sense if you still manage to keep the diffusor working. It massively helps in terms of setup variance and therefore rear end traction.
Gerhard Berger wrote: I think his answet to the last question is more "I've made cars in the past without EBDs, so i'll do what i did back then".
No. Just watch my translation of the discussed article:
gandharva wrote: Quick summary of Neweys words:
- Some hint that we won't see the ramp in 2014 as it was only a compromise with small benefits and only done because of exhaust exiting on the side was allowed
- Webber has more "aerodynamic feeling" for the car than Seb but general design route followed CFD and not drivers feelings
- Engine mappings had huge influence in 2013
- Biggest 2014 problem is the frontwing. -> Design decision between rounting air on the inner or outer side of front wheels
- V6 engine packaging is 2x to 3x more complex than with V8s
- "I used rake as no exhaust blowing was available and I will try to do it again"
SectorOne
There will be rake. Just not as much as today.
Owen.C93
Owen.C93
172
I think the RB10 is going in-wash this year. I imagine the front brake duct vanes will become a big development area next year.
lio007
315
the RB10 could be look like this (by Matt Sommerfield)
Burgess
Burgess
A pretty rough drawing then, FW doesn't look legal neither does the nose.
beelsebob
beelsebob
85
I don't understand why everyone is drawing coanda exhaust bulges on these. The exhaust being there is banned in the new regs, so there's no benefit to adding that bulge blocking a chunk of the coke bottle.
Holm86
245
That just looks like a bad copy of scarbs drawing.
Owen.C93
Owen.C93
172
It's only summers.
I did hear that RBR have done something slightly different to the new nose regs. The guy isn't huge on F1Tech but he said it did look different from Scarb's drawing. We've seen lots of teams run basic launch cars at the first test and I expect this to be even more common while they sort out the engines before homologation which is after the first or second test I believe.
scarbs
scarbs
393
Owen.C93 wrote: I did hear that RBR have done something slightly different to the new nose regs. The guy isn't huge on F1Tech but he said it did look different from Scarb's drawing. We've seen lots of teams run basic launch cars at the first test and I expect this to be even more common while they sort out the engines before homologation which is after the first or second test I believe.
I've also heard the RB10 will have a different nose to my drawing and it is a solution thats been talked about on this forum.
