Ferrari F14T
Re: Ferrari F14T
Italy 2014 - Saturday (06.09.2014)
hollus
Re: Ferrari F14T
I found a few videos of Raikkonen in Monza and his gear change seems to be limited to making 8th about 3% longer. 4th to 7th seem untouched, as does 2nd. They might have made a minor change to 3rd but the time he spends in that gear is minimal and often has wheelspin, so most likely it is just a data artifact.
No data about 1st and so far no data on whether Alonso has the same change or not.
Edit: It looks like they changed the gears for both cars. 1st is unseen so far, 2nd to 7th appear unchanged and 8th became 2.7% longer.
Rivals, not enemies.
McMrocks
McMrocks
32
Re: Ferrari F14T
stefan_ wrote:Italy 2014 - Saturday (06.09.2014)
http://i.imgur.com/zu1BxEz.jpg
http://i.imgur.com/KUuD8yT.jpg
Could someone explain me why there is some downward flow, please?
NoDivergence
NoDivergence
50
Re: Ferrari F14T
I would guess 3D effects
Re: Ferrari F14T
I'm assuming the strakes in the diffuser? Those strakes, If I'm correct, cause a pressure difference on the in/outside of the strake, thus air bleeds under the strake to shed a votex, which explains the downward flow on some of the strakes.
McMrocks
McMrocks
32
Re: Ferrari F14T
wesley123 wrote:I'm assuming the strakes in the diffuser? Those strakes, If I'm correct, cause a pressure difference on the in/outside of the strake, thus air bleeds under the strake to shed a votex, which explains the downward flow on some of the strakes.
So a kind of wing tip vortex on the strakes?
Re: Ferrari F14T
Yes. It is visible because of the difference in paint coverage on the left hand side compared to the right hand side.
Re: Ferrari F14T
Formula1.com
joeyg02
Re: Ferrari F14T
Looks like they went back to the spa diffuser.
Drafting & Design Engineer - I crave information & live in a never ending quest for answers to whatever piques my curiosity.
Joey Griffin - Owner - JG GraphX.
Lifelong Motorsport Fan from Southern Georgia, United States.
Re: Ferrari F14T
joeyg02 wrote:Looks like they went back to the spa diffuser.
We've seen that this year. On several occasions they test parts they're gonna use in the next race. They probably didn't need the xtra downforce in Monza. Although I would suspect that there would be less drag associated to diffuser downforce.
Re: Ferrari F14T
Singapore 2014 (Thursday 17.09.2014)
Frafer
Frafer
Re: Ferrari F14T
that RW comes straight from Montercarlo, that's the end of F14T updates i guess
f300v10
f300v10
185
Re: Ferrari F14T
Better view of the modified barge board, now with second element. This has been on the car for a few races but I haven't seen a clear shot like this before:
f300v10
f300v10
185
Re: Ferrari F14T
Hard to be sure as the angle is not a good one, but there apear to be new and much larger front brake ducts:
Re: Ferrari F14T
Frafer wrote:that RW comes straight from Montercarlo, that's the end of F14T updates i guess
Why so? This particular rear wing is built to produce the most amount of downforce possible. Since Monaco and Singapore are aero-wise close cousins, it's only natural to bring the Monaco spec one.
One shouldn't forget that the current cycle of rear wings is very, very limited in what they can alter and develop, close to being a standard part. Combine that with the fact that the RW regulations haven't changed much since 2009, only further restricting design freedom by removing slots in the wing elements in 2011 and a shallower main plane in 2014, and it isn't hard to see the same wing for the same type of circuit.
