(KVRC15) TF_SP
AratzH
(KVRC15) TF_SP
Hi all!
I think it is a good time to unveil my entry for this years KVRC 15. It is still way of being fully optimized but I need data from the first entry to center a little bit my simulations.
As allways all comments are welcome!
MVRC -> TF
Daliracing
Re: (KVRC15) TF_SP
Wow nice car! it looks pretty fast :D
CAEdevice
Re: (KVRC15) TF_SP
Interesting project!
Are there some inlet (coolling) in front of the rear fenders? The cooling outlets are that rectangles above the diffuser?
machin
162
Re: (KVRC15) TF_SP
Cool! Looks very much like a real LMP1... Will be interesting to see how it compares to something like Variante's car....
AratzH
Re: (KVRC15) TF_SP
They could be inlets, but the rules state that only one inlet per side is possible. Actually is a geometric result of the operations that made the rear fenders :P
Regarding the outlets you are correct Matteo!
MVRC -> TF
MadMatt
MadMatt
125
Re: (KVRC15) TF_SP
Nice one! Finally someone with swan type rear wing mount and shorter rear deck!
AratzH
Re: (KVRC15) TF_SP
So after the not so good results of race 1, I present the second iteration of the TF_SP LMP. I did change the whole desing concept from front wing to front diffusser, new rear wing and endplates and more agressive location of the mandatory inlets-outlets and other anciliaries.
As usual some pictures:
Simulations sugest almost twice the downforce for a similar amount of drag (something I quite doubt haha) but it should be an improvement.
Anyway coments are very welcome!
MVRC -> TF
machin
162
Re: (KVRC15) TF_SP
Oooo.... That's different... I like the look of it....
Is that front fairing hiding something like the diffusers we saw at the rear of the top three entries from last round......?!
Re: (KVRC15) TF_SP
I sense some inspiration from the Toyota GT-One
AratzH
Re: (KVRC15) TF_SP
Actually the GT-One was a big source of inspiration at least concept-wise. But making that concept work was harder than I thought.
Regarding the front diffuser the idea (and the profile) are similar to the rear one. The main difference is the way (or the place) air is extracted. I did try most options: over the sidepots, to the side even flow trhough.
We will have to see how it compares with the front wing concept in terms of downforce and drag.
MVRC -> TF
variante
133
Re: (KVRC15) TF_SP
Brilliant design! So elegant that it could be sold as a production supercar :D (excellet CAD skills too!)
I like the solution you've adopted for those cooling inlets, though a smoother transition might have helped the airflow to the rear end.
You're fighting for the podium now, aren't you? Good luck
AratzH
Re: (KVRC15) TF_SP
Thanks Variante! I hope I can fight for the podium :P
MVRC -> TF
AratzH
Re: (KVRC15) TF_SP
New race and I hope some step forward. I have revised front and rear diffuser, cooling and rear wing. All minor changes but they should improve downforce a little.
Now the pictures!
As usual all coments are welcome!
MVRC -> TF
CAEdevice
Re: (KVRC15) TF_SP
Your design is becoming more and more interesting. I noticed that you have vortex generators on the front wing.
variante
133
Re: (KVRC15) TF_SP
It looks like you've abandoned many solutions from your last model. The most visible change, however, is the introduction of a JJR-like cooling inlet...have you tested both solutions and found out that his was the best, or have you made that choice intuitively? (my B-spec model, imposed by the new regulations, will probably feature those inlets, even though i'm trying to think to a different yet equally effective solution, for originality's sake...)
Nice model, anyway! If your diffuser's updates work, you're a candidate for the best performing rear end (i shall advice you that i've got many updates on that side :D)
Seriously, it would be interesting to understand where you rear end performance comes from...how much the undisturbed flow coming from the front increase the rear downforce?
