Mercedes Turbo is the compressor at the front?
hemichromis
hemichromis
This is what we have been told by analysts since last year But look at this image from
http://www.mercedesamgf1.com/en/car/pu106a-hybrid/ of the 2014 engine:
Can anyone shed light on this?
hemichromis
hemichromis
Re: Mercedes Turbo is the compressor at the front?
http://formulafreak.kinja.com/craig-sca ... 1656299441
So it looks like Mercedes were trying to mislead their rivals with this picture!
jure
jure
The picture in the first post is just for marketing purposes and it has no correlation to the real power unit.
ian_s
that picture is total rubbish. the exhausts feed into the turbine which is closest to the engine, where does the exhaust gas go after that? into the V? hardly likely!
Just visit the Mercedes Engine Thread, there are Pictures of the actual Engines raced in F1. Not just marketing rubbish.
riff_raff
riff_raff
hemichromis wrote:http://formulafreak.kinja.com/craig-sca ... 1656299441
That video clearly shows a compressor housing at the front of the engine. What is especially interesting is the A/R ratio of the compressor housing. It has a very large diameter. The turbine housing is much smaller in comparison, so it seems there is some method of varying the speed between the turbine and compressor.
A: Start with a large one!"
noname
noname
riff_raff wrote:(...) What is especially interesting is the A/R ratio of the compressor housing. It has a very large diameter. The turbine housing is much smaller in comparison, so it seems there is some method of varying the speed between the turbine and compressor.
I do not think so. It's not different than other turbochargers. Maybe except the one which is not working properly.
ian_s
thats against the rules. the compressor and turbine have to spin at the same angular velocity
563
riff_raff wrote:That video clearly shows a compressor housing at the front of the engine. What is especially interesting is the A/R ratio of the compressor housing. It has a very large diameter. The turbine housing is much smaller in comparison . . . .
It is difficult to judge the A/R visually. The reason the Mercedes compressor looks so big is that the diffuser is radial. Most turbocharger compressor housings are "folded (rolled)" to reduce the outside dimension. Mercedes packaging has allowed them to avoid this step. Here is a comparison of the two shapes.
563
A better image of a compact volute. You can see that the diffuser section is contained within the volute.
gruntguru wrote: โ†‘
23 Dec 2015, 03:01
http://i.imgur.com/E5m4esT.png
:shock: :o
Whooooaahhh...
They finally meet! Two titans!
I must say, I am not used to someone trying to show riff-raff something!
