When the tank sack inside it's housing is empty, is it vacuumed. So that when fuel flows in when the car is fueled up, there is no air in the tank? Making the sack only filled with fuel and nothing else, so that in the event of a shunt or crash, the fuel doesn't slosh about in the tank?
Or is the tank exposed to the outside air making the sack pressurized/having to take air out as fuel flows in?
If the sack is pressurized: does this infuence the probabilty of it bursting in a crash when a foreign object tries to penetrate the Kevlar sack?
If they let air in when fueling up: does the sack become negatively pressured when the car is using fuel and emptying the sack, making it deform in the tank's shell? Or is it tightened down that much that it doesn't deform under the force of the fuelpump?
Hope someone can tell me a bit more, I see something in the technical regulations for 2021 saying that you should or shouldn't pressurize the tank. Article 6, p. 49
Doing some research on the fueling in F1 for a college project (automotive engineering, applied sciences).
Thanks a lot, an intrigued student
