New Abu Dhabi 2021 circuit laps - simulator
AeroDynamic
349
Hadn’t seen this before. Karun Chandhok drives the simulator around the new Abu Dhabi track where our season finale will be decided. What’s your thoughts for the championship contenders?
BlueCheetah66
BlueCheetah66
32
Re: New Abu Dhabi 2021 circuit laps - simulator
I'm a bit worried for Red Bull here. Two of the places I would expect them to gain time are now eliminated.
Looking on last year's qualifying comparison, the difference between the cars at the old track was small. I also agree with the wider community that the new track changes take away the premium on rear traction thus the advantage will swing to Mercedes.
Examining last year's qualifying:
The RedBull seems to have better low speed traction on corner exit as you see in old turns 5, 6 , 7. Then on old turn 8, the Mercedes seems like it catapults from the corner. This was not because it has gained a strong rear end all of a sudden, it was only because of the off-camber corner that helped to load up the Mercedes rear outer tyre. The story of strong rear end and traction repeats for the RedBull out of turn 17 where it pulls ahead once more. The rest of the lap is pretty even stevens. One thing I noticed was the RedBull seem to lose tyre grip later in the lap.
227
The track is much much faster, and the setup does not have to be compromised too much by the tight section.
Now we can have more overtaking.
siskue2005
70
ringo wrote:
23 Nov 2021, 15:36
The new turn 9 looks like turn 1 of qatar (but inon the opposite side)
