Valkyrie aerodynamics
Fluido
Fluido
1.How venturi tunnels at Vakyrie works if they are so much high from ground, I mean you can sleep under the car?
To get max low pressure throat section must be close to ground.
Can you post side view of tunnel?
2.Part of "diffuser" that is behind rear wheels have huge lateral expansion, how flow stay here attached?
I think adverse pressure gradient is too strong here, flow must deattached.
3. Did they change tunnels design, I see on some pics. differnt desing, T shape at bottom?
4. Can this car have Cd=0.30? Inst that too small for such huge downforce car?
Greg Locock
Greg Locock
233
Re: Valkyrie aerodynamics
Cd=0.30 seems very unlikely indeed if it is producing 2g (?) of downforce.
Fluido
Fluido
Yes it sound too low.
BlueCheetah66
BlueCheetah66
32
The Venturi tunnels will likely have some sort of vortex structures within it, either from the front wing. The biggest indicator of that is that the tunnels are very rounded in shape, to keep the vortices strong throughout. This will also help the flow stay attached though the lateral expansion
Fluido
Fluido
BlueCheetah66 wrote:
30 Oct 2023, 12:12
So Adrian on purpose send vortex in the tunnels, he dont wont laminar flow in tunnel?
Why vortex flow follow curved surface without separation?
where is peak suction, any CFD of that car?
n_anirudh
n_anirudh
Flow will be turbulent at high speeds Not laminar anyways.
VOrtices are used for floor sealing
The floor would have been optimised for a range of operating conditions with sensitivities to yaw/ride height etc., and any CFD would be user based - not company provided.
n_anirudh
n_anirudh
Greg Locock wrote:
29 Oct 2023, 22:52
Only frontal drag, not inclusive of the induced drag at high speeds
Hoffman900
Hoffman900
168
Fluido wrote:
30 Oct 2023, 12:28
30 Oct 2023, 12:12
All floors respond favorably to vortex generation. The strakes as you see them on F1 cars have been in use on tunnel cars (Indy / Cart) going back to the mid 1990s.
See here:
https://www.researchgate.net/figure/Sch ... _228616843
