The Red Bull Advantage in 2011
SiLo
Does anyone think Red Bull will carry the advantage over to next year? This year was again simply an evolution of last year (which seems the same for Mercedes) and the large rule changes would surely necessitate a complete overhaul.
I've always thought that "evolution" cars seemed to be better than new from scratch ones, even if new ones have newer/better ideas on them. Simply because the understanding of the car is that much more. What do people think?
Reason: edited title to reflect topic
Felipe Baby!
Neno
Neno
-29
Re: The Red Bull Advantage
Red Bull dont have advantage next year in F1! With new rules, and 5 teams in battle for championship dont have a single chance.
tommylommykins
tommylommykins
-1
hmm, wouldn't it really only depend on how much faster your new car is than all your other rivals', whether or not it's a cleansheet or an evolution?
I guess if you think that your current car has few flaws and is a good base to progress from then producing an 'evolution' car means you have to spend less time on redesigning things from scratch and can spend more time on making the car go faster.
As a bit of a side note, what is the true difference between an evolution car and a from-scratch car? I assume the vast majority of components in cars stays the same between different years...
It's only the aerodynamics that we can really see when things change... If a team keeps the external aerodynamics of the previous car and puts in completely new internals, how do we know? Do we think it's the same car as last year's? What if the team uses the same internals but has completely different aerodynamics? Is that a new car or an evolution car?
raymondu999
There's not MUCH changed next year... It's 2013 that's got the big rule changes, changing to ground effect (or was that 2012?). Besides, Adrian Newey, in my memory, has always been the designer to have in effect of a rule change
失败者找理由,成功者找方法
donskar
donskar
Re: The Red Bull Advantage in 2011
SiLo wrote:Does anyone think Red Bull will carry the advantage over to next year? This year was again simply an evolution of last year (which seems the same for Mercedes) and the large rule changes would surely necessitate a complete overhaul.
Red Bull will maintain their advantage, unless that advantage -- Adrian Newey -- moves to another team.
gibells
gibells
mmm. Depends. Ferrari Renault and McLaren have had a great deal of experience ironing out the KERS problems they had at the start of last year. To that end I'm not sure. I'd be very interested to see whether Red Bull goes with or without it. If they do go KERS, I should think they may be on the back foot for at least the first 3/4 races. If not, I think they'd be fast but will loose advantage when the KERS cars tune up.
donskar
donskar
gibells wrote:mmm. Depends. Ferrari Renault and McLaren have had a great deal of experience ironing out the KERS problems they had at the start of last year. To that end I'm not sure. I'd be very interested to see whether Red Bull goes with or without it. If they do go KERS, I should think they may be on the back foot for at least the first 3/4 races. If not, I think they'd be fast but will loose advantage when the KERS cars tune up.
KERS will -- again -- pose challenges in packaging and aero. Newey is strong in both areas. As to the specific operational challenges of KERS, I don't think RBR will have any difficulty recruiting the appropriate technical/KERS personnel. (I'd love to be wrong about this.)
timbo
timbo
111
We all agree that RedBull is best car this year, but still there are drivers from 3 teams fighting for the championship.
It's not like all Newey's cars won a championship, right?
Surely RedBull has the most solid base for next year, and it would be most logical to bet on them for next year. But I think other teams are doing their best and learning from them to raise a challenge next year.
Nothing really groundbreaking I have said here, sorry :)
ESPImperium
ESPImperium
64
The only real changes to the cars next year are:
*Double Diffuser and F-Duct being banned
* Anvil wings being banned within a 150mm radius of the chord of the rear wing (has this been confirmed?)
* The introduction of the adjustable rear wings
* Mandatory 46/54 weight distrubution
* Re-Introduction of KERS
* Pirelli P-Zero Rubber
* Car weight increased from 620KG to 640KG
The big ones are the rubber and Diffuser, but i think the RB6 and F10 are the best baselines for 2011, but the R29 is as good and now C29, FW32 and W01 are looking loke good baselines to improve the whole aero area.
The rest are looking at clean sheet designs.
RedBull will use Renaults KERS? I´m not sure how much they improved their system since 2009..
the mercedes propelled car sseem to have a considerable head start with the system already available.
Now for the extra weight mandated for the complete car ...is this dictating a lot in conjunction with the mandatory weight distribution in terms of component positioning or is this extra ballast just used to lower the CoG ...
aral
aral
26
marcush. wrote:RedBull will use Renaults KERS? I´m not sure how much they improved their system since 2009..
I understand that the new weight limit is to allow for the addition of KERS. This will no doubt, be located as low as possible. But here is a question. Does the weight balance have to be the same, both before and after a race? This could be difficult to control due to position of fuel cells. Any info?
JohnsonsEvilTwin
Weight distribution must all be equally set before qualy 1 as I understand it.
That is when the cars are to be checked.
More could have been done.
David Purley
Holm86
245
Has this mandatory weight distribution been confirmed?? Havent heard much about it.
If its true its a stupid rule.
Giblet
Giblet
The car seems to be doing something this year that nobody can really figure out. If the next car is made of a harmonious bag of tricks that nobody can fully undersand it could also be a touch on the dominant side.
CHT
CHT
RBR has managed to produce championship winning cars for 2 consecutive years despite not being the biggest or richest team on the grid. There must be something really special about the RB5/6 design that make them so quick and adaptable to changes.
I reckon that the longer the WDC/WCC drag on, the more RBR will gain for next year.
