Mc Laren MP4/24 aero-mech development in 2009
Post Tue Oct 27, 2009 2:24 pm
As our Moderator, Ciro, has attempted to point out, this thread is not for discussing anything but the technical development of the car.
Please listen, and let this post be a line in the sand, thanks.
Giblet
Post Wed Oct 28, 2009 8:37 pm
Pu-leez. I have had two reports about this thread already. No more speculations, they will be moved or erased. Please, use the NEW THREAD button if you have the urge to explain why something else happened.
Ciro
Ciro Pabón
Post Thu Oct 29, 2009 4:16 pm
bar555 wrote:EXHAUSTS - SINGAPORE
DIFFUSER - SINGAPORE
FRONT BRAKES - SINGAPORE
looking at the bottom pic of the front brake assembly it seems there is a secodary air intake feeding air to the brake caliper... I haven't noticed any discussion of this in this, or other threads, (but accept I m ight have missed it!)... is this unique to Macca??
Also... there are a lot of sensors feeding through hthe upper wishbone - anyone care to speculate on what these are measuring... Temperature is a obvious candidate, wear of the disc/calipers another... but there seem to be planty of sensors there...
Mike
Mikey_s
Post Thu Oct 29, 2009 4:29 pm
Mikey_s wrote:Also... there are a lot of sensors feeding through hthe upper wishbone - anyone care to speculate on what these are measuring... Temperature is a obvious candidate, wear of the disc/calipers another... but there seem to be planty of sensors there...
I'm also curious as to what all the sensors are.
I’ve never noticed the adjustable Ackerman before, neat.
razzmyth
Post Thu Oct 29, 2009 4:39 pm
compo
Post Thu Oct 29, 2009 6:54 pm
Mikey_s wrote:looking at the bottom pic of the front brake assembly it seems there is a secodary air intake feeding air to the brake caliper... I haven't noticed any discussion of this in this, or other threads, (but accept I m ight have missed it!)... is this unique to Macca??
Oh yes, there's the big air scoop and below there is a little pencil thin periscope of an air duct. I wonnder what that is for.
richard_leeds
Post Thu Oct 29, 2009 7:05 pm
Mikey_s
This wing-like element with the horizontal hole helps to cool the brake calliper itself .It has been already illustrated in page 2 at the current thread ( viewtopic.php?f=6&t=6599&start=15 ) . Toyota uses a similar concept reverted -L shaped winglet in the TF109 .
The idea is not new as Ferrari first introduced an additional brake cooling winglet-style element back in 2005
F2005
Future is like walking into past......
Blog : http://formula1techandart.wordpress.com/
Twitter :http://twitter.com/bar555onF1
bar555
Post Wed Nov 04, 2009 4:46 pm
goony wrote:wheel speed brake wear and temp
if u can find sum pics of the mirrors we had thermal imaging cams in them for a time to check tyre temp on the go
goony
There would also be an receiver for a "pickup" of the internal tire air pressure located in this area, as it's transmitted by wireless through the wheel... the "accurate" range for the receiver is 2 feet unless that has been improved in recent years and can be put on the chassis, some 3.5 feet away.
I too would like to thank BAR555 for the great posts this year hopefully you will do the same next year.... great job!!
"Driving a car as fast as possible (in a race) is all about maintaining the highest possible acceleration level in the appropriate direction." Peter Wright,Techical Director, Team Lotus
speedsense
Post Wed Nov 04, 2009 6:04 pm
speedsense wrote: I too would like to thank BAR555 for the great posts this year hopefully you will do the same next year.... great job!!
thanks speedsense ,
The 2009 season is not yet over for me . I will continue working on the M4/24 technical evolution , enriching further this thead ( and similar threads as well ) .
As regards the 2010 season , i can not tell for sure whether i will do analogous topics or not .
bar555
Post Wed Nov 04, 2009 6:26 pm
bar,
I have no idea where you ge the pics or where you find the time to do what you do, but it is great and thanks for doing it.
Fantastic effort.
Mike
Mikey_s
Post Wed Nov 04, 2009 11:08 pm
Mikey_s wrote:bar,
Fantastic effort.
x 2
richard_leeds
Post Thu Nov 05, 2009 3:06 am
richard_leeds wrote:
Mikey_s wrote:bar,
Fantastic effort.
x 2
X3 Pics are unbelievable!!!
IT IS WHAT IT IS
TRICKLE69
Post Sun Nov 08, 2009 12:39 pm
EXHAUSTS - JAPAN
DIFFUSER - JAPAN
FRONT BRAKES - JAPAN
bar555
Post Mon Nov 09, 2009 2:40 pm
The brake rotor adapter plate is a slightly different design (thicker) and has 10 nuts instead of 6. Possibly higher braking loads in Japan?
razzmyth
Post Mon Dec 14, 2009 8:42 pm
GP of BRAZIL
Undergone changes from Japan
1.A modified front wing was tested but not finally used for race
2.Revised rear wing
3.Symmetricity to exhaust outlets was the choice for this race
bar555
PreviousNext
Who is online
Users browsing this forum: Ahrefs [Bot], GSBellew and 8 guests
