Having a big time problem in getting the assembly right .
mahesh248 wrote:I would like to know if any one has an upright assembly drawings , in solidworks , its really importatnt , so if you got kindly post it . Thank you
RacingManiac wrote:Japanese teams at least make their own thing, despite sometimes how wacky they may be in the earlier days. Upright in general should be fairly simple. Especially if this is a conservative attempt at the first one. You know your points(I hope), you know your wheel bearing size, you know the brake system you are using and you know how much space you have inside the wheel. Just draw something and connect the dot first, then think about optimizing it. That way at least you'll have something....
You shouldn't be designing upright anyway unless you have most if not all of those somewhat defined....
Tim.Wright wrote:mahesh248 wrote:I would like to know if any one has an upright assembly drawings , in solidworks , its really importatnt , so if you got kindly post it . Thank you
Mate, lucky you didn't post this on fsae.com. I think I would see the flamage from Germany...
mahesh248 wrote:I posted the same thing few years back and replies were different
Users browsing this forum: Yandex [Bot] and 1 guest
