Williams FW32 Cosworth
Post Sun Jul 18, 2010 4:06 pm
wow check that beam wing :O
Great shots once again zgred!
Post Sun Jul 18, 2010 4:26 pm
is that an f-duct fin? It looks awfully small/thin if it is
失败者找理由,成功者找方法
raymondu999
106
Post Sun Jul 18, 2010 5:53 pm
raymondu999 wrote:is that an f-duct fin? It looks awfully small/thin if it is
It's your average shark-fin connecting to the rear-wing. :)
"It could be done manually. It would take quite a while, but it could be done. There is however a much more efficient and accurate way of getting the data. Men with lasers." Wing Commander Andy Green
roost89
Post Sun Jul 18, 2010 6:59 pm
Yes, it is. It has a slight triangular profile, with the bottom being wider that the top, which is ery thin. The slot in the rear wing can be seen in the second photo.
gilgen
Post Sun Jul 18, 2010 7:13 pm
wesley123 wrote:wow check that beam wing :O
Yeah the beam wing has a slot on the backside like the main beam of the rear wing.
"I was blessed with the ability to understand how cars move," he explains. "You know how in 'The Matrix,' he can see the matrix? When I'm driving, I see the lines."
n smikle
Post Thu Jul 22, 2010 4:48 pm
I find this interesting: http://www.autosport.com/news/report.php/id/85425
Maybe because they don't have somebody of Adrian's or Ross' caliber at the helm of their technical staff, they need very experienced driver to give technical feedback and show positive direction. Probably Nico doesn't have much experience for this role.
timbo
Post Thu Jul 22, 2010 9:25 pm
Courtesy of nextgen-auto.com
imightbewrong
Post Sat Jul 24, 2010 8:20 pm
Join the chatroom during GP weekends!
mx_tifoso
Post Sat Jul 24, 2010 8:51 pm
From that shot it looks like the exhaust runs all the way down and back behind the diffuser completely. Must be an optical illusion.
volarchico
Post Sat Jul 24, 2010 9:29 pm
volarchico wrote:From that shot it looks like the exhaust runs all the way down and back behind the diffuser completely. Must be an optical illusion.
I suspect it's hooked up to some sort of venting system, where the exhaust gases are fired straight out of the building =)
roost89
Post Sat Jul 24, 2010 9:30 pm
Most likely!
Otherwise the exits are below the ground.
Anyway, Williams car improved quite a bit. Nice to see them fighting in top-10 again!
timbo
Post Fri Jul 30, 2010 11:23 am
zgred
Post Fri Jul 30, 2010 12:29 pm
WOW ! That's a masterpiece of a pitot-tube array. They must have a new front wing and/or new splitter if they are so keen to get some flow data on that area.
"Advances are made by answering questions. Discoveries are made by questioning answers" -Bernhard Haisch
kalinka
Post Fri Jul 30, 2010 12:48 pm
^^It seems to be a new floor with some different front shape underneath the sidepods..... :roll:
raceman
-1
Post Sat Jul 31, 2010 9:14 pm
Francesc
PreviousNext
Return to Formula One cars
Who is online
Users browsing this forum: 3one, Banki, Crabbia, dans79, gilgen, henry, jackob183, MacX, marco.pav94, Ral, senja, Twitter [Bot], wesley123 and 66 guests
