manchild wrote:BTW, Lotus reported that their discovery of a problem will lead to modifications on both chassis, which means that it was not an error during production of this one or an accident that caused problem, but a design flaw they haven't noticed in Jerez.
"It's the kind of thing that you can fix, ideally back at the factory in a controlled environment. But you could do that in one day so if they aren't going to run this week, it suggests that they maybe need to do more than just inject glue and put fasteners in. So it could be a more dramatic problem and maybe it will need new chassis.
"Chassis 3 would likely be on its way for Melbourne and might be at the point in the manufacturing process where you could integrate the fix properly. If they did that, it's possible that Lotus might have to have that chassis and one patched up one for Melbourne as it's a tight turnaround to build a fourth chassis if it hasn't started."
Anderson adds that he feels the problem is more likely to be a manufacturing fault than a design error.
Tyler wrote:I would really appreciate it if someone would explain the whole process of how the chassis gets built as well as how many and at what stage and how it fits in with the crash tests and just the general timeline of things.
Is it usual for a team to build 3 chassis'?
Sorry if my question seems a bit silly and vague - I just have no idea on this process and would love someone knowledgeable to explain it in detail.
j3st3r wrote:
..SNIP...
From previous seasons most teams use 2 - 3 chassis per driver... so a total of 6-8 chassis per season is fairly normal.
manchild wrote:It's not that much of a cost at all. In 2006. Alonso used just one chassis for whole season and won the championship. Even if it is 600.000 euros per chassis, teams spend much more on technology with FIA defined minimum life expectancy which is also "frozen" for the sake of "cost cutting", including traveling, accommodation, hospitality, catering, advertising, printing and other secondary costs during one season.
Oskari Saari wrote:Lotus just confirmed to me that the team is seeking permission from other teams to use 3 days they wont drive in BCN in a private test.
bhallg2k wrote:Oskari Saari wrote:Lotus just confirmed to me that the team is seeking permission from other teams to use 3 days they wont drive in BCN in a private test.
That seems a bit optimistic.
While it would be a nice gesture, I see no reason for other teams to consent. It just seems wrong to give a team special dispensation because they screwed up.
mith wrote:Speaking of that, how was Mercedes able to have private test without asking other teams for permission?
Users browsing this forum: AddThis [Crawler], Baidu [Spider] and 21 guests
