Lotus E21 Renault
Matt Somers
Matt Somers
179
Re: Lotus E21 Renault
Blackout wrote:
wesley123 wrote:
Blackout wrote:
The mount looks a bit longer, thats all.
I never said it is blowing something. That was strelok's assumption and I said 'why not ?'... after all the things we saw these last years ... :P
And yes it's thick and looks rounded. It definitley looks intriguing when compared to the usual anti flexing mounts.
Might be a big vortex generator. why not :?: :P
I'm tired so can't say my posts will be coherent here but the several things that sprung to mind when I first saw it yesterday:
A) It could be blowing the front edge of the Tea Tray with a duct at the top end
B) It simply helps to augment the airflow to the Sidepods/Bargeboards that the Pelican Nose is already deflecting (Progressional upgrade)
Here's another angle of it:
Matt Somers
Matt Somers
179
korzeniow wrote:But why Lotus' ramp doesn't smooth into the floor like RBR's?
RBR's various versions of the tunnel last season saw them try differing tunnel/ramp lengths in combination with the length of the vertical strake. I think the most important thing to realise about Lotus' version of the tunnel are they haven't shrouded the halfshafts so are still trying to utilise the halfshafts for DF generation and their tunnel ramp doesnt blend into the floor suggesting internally they needed the additional space to make their current internal dynamics work with the tunnel concept.
AnthonyG
38
RB has the same winglet (dunno if its something from last year allready)
Richard
Richard
korzeniow wrote:There are post-2009 rules stating that sidepod bodywork 50mm above the floor must meet tangential and minimum radius regulations. Hence the sharp edge of the tunnel'.
Thank you! I read the original comment as referring to the hight of the floor above the ground, a ride height mechanism!
That sharp edge really does help identify the tunnel, it certainly looks longer than the RB tunnel .... although who knows what will turn up at Melbourne.
korzeniow
korzeniow
I don't know how step on the ramp would benefit in downforce from disturbed air from spinning halfshaft. For me it doesn't sound right. But maby you could explain more about this.
I think they wanted to improve the effectiveness of the tunnel and the step was the result of raising the ramp
February 5, 2013
Matt Somers
Matt Somers
179
The ramp ending at the floor (RBR) will have the airflow at a lower point than the step to the floor (Lotus) meaning the airflow to the halfshaft is distributed further/higher along the floor (Tired so probs not my best explanation)
Owen.C93
Owen.C93
172
I think you're way over estimating the importance of drive shaft downforce. And even then the more shapely floor around the tyre is a bit of a stretch.
miguelalvesreis
miguelalvesreis
Can it be a version of Sauber's S-Duct?
MarkedOne8
MarkedOne8
They don't need to smooth the end of the ramp because that part is probably too far back to have effect on the exhaust gases, but that step on the ramp, comparing to RB, gives Lotus' ramp a bit more capacity. I don't which one' solution is better, but Lotus is, I think, playing on the capacity of tunnel.
As I said earlier, I'm pretty sure that the splitter support is actually a tube, it is hollow. I don't know if the rules are allowing any tubes to pass through the bodywork around plank area. These tubes would be sending the air from front to blow something at the back (diffuser, starting hole, whatever). Or maybe... tubes are not necessary, maybe it's purpose is to insert that extra air under the plank to increase the pressure so the diffuser effect will be higher when it extracts the air.
P.S. I'm not that type of guy who expects almost everything to be blown. I'm not RB/Newey fanboy etc.
Fernando Alonso is the best pay-to-drive driver in F1 with the biggest amount of money behind him.
http://f1bias.com/2012/04/05/truth-abou ... nder-2008/
is it me or is the overal splitter in that area very fat? could it be that they house the ECU in it or something?
MarkedOne8
MarkedOne8
wesley123 wrote:is it me or is the overal splitter in that area very fat? could it be that they house the ECU in it or something?
Technically I don't know, but visually it's pretty similar to RB's one.
It's not like F-Duct, it's not connected to the inner side of the cockpit. The driver's influence is forbidden. It's could be something like brother version of DRD, but in this case, the blowing target is different.
tepek
tepek
Is it me or there is a tunnnel under the sidepod in the floor?
Matt Somers
Matt Somers
179
Owen.C93 wrote:I think you're way over estimating the importance of drive shaft downforce. And even then the more shapely floor around the tyre is a bit of a stretch.
Perhaps, if it's coming across that way but merely trying to show why Lotus have adopted a different solution. The most important reason for the shrouding of the halfshaft is raising the wishbone clear of the floor and not placing it under the halfshaft. This allows for a more unobstructed flow to the rear of the car - Source: Andrew Green, Sahara Force India (I was at the launch of the VJM06 and when asked that was his frank response)
Jerez - Day 3
korzeniow
korzeniow
So, Kimi will be working on aero this morning
February 5, 2013
