In Yellow Raikkonen short wheelbase.
+1turbof1 wrote: This is a better explanation:
http://thewptformula.wordpress.com/2013 ... enerators/
Thanks, but in all fairness the article isn't mine. The above posted blog is made by the same member here, thewptformula. Greatly gifted kid; quality alike scarbs his pieces, and he makes tech updates every race.henra wrote:+1turbof1 wrote: This is a better explanation:
I was also a bit confused by the explanation given by GA. It didn't match to my understanding of these VG at all.
Now this one sounds much more realistic.
Edit: In all fairness to GA I think there is still an element of truth in his explanation. The agressive outward bent shape will also help to direct the airflow somewhat to the outside pointing to the exhausts which are quite on the outside of the sidepods and will also help to prevent it from being blown inward by the flow along the sides of the sidepods.
It all about aiming the airflow to the exhausts and kepp it attached to the upper side of the sidepods.
Oh, that is probably even the part which is outright wrong.turbof1 wrote: In this instance he puts all the emphasis on the lift reduction. While it might perhaps be true, that really is not why the teams installed thos VG's.
I was too careful on that; I was suspecting the same .henra wrote:Oh, that is probably even the part which is outright wrong.turbof1 wrote: In this instance he puts all the emphasis on the lift reduction. While it might perhaps be true, that really is not why the teams installed thos VG's.
Chances are the VG will even increase direct lift over the sidepods.
The only thing where he might be right is that they try to move the flow towards the outside of the sidepods, not just creating vortices.
They can add carbon layering, within the boundaries layed down by the rules, to increase the resiliance. But that comes at the cost of extra weight, or perhaps even a big redesign of the floor, which is both costly and eats away performance, the reason probably why they left it as it was when it happened to Romain. They probably thought to get away with it again when it happened to Kimi.iceman07 wrote:hello,
may I ask what can the team do to avoid a floor deflection test failure in the future? and why they didn't do any needed modification since it damaged with Grojean before?
I had been wondering about this. Would it genuinely have been a case of "getting away with it" had Kimi not been penalized?turbof1 wrote:[snip] They probably thought to get away with it again when it happened to Kimi.iceman07 wrote:hello,
But few cars go wide and hit the kerbs that are situated at turn 3 exit. We 'saw' three cars hit those Kerbs: Hamilton at the beginning of his first fast lap in Q3. He goes wide, the car bottoms and even jumps and, short time after that, one of his wishbones breaks. Brawn says one of the kerbs could be responsible for that. Brundle too.theWPTformula wrote:I think it was a bad decision. Why penalise the team for almost exactly the same infringement that went unpunished months ago. Again the stewards lack consistency.
Having said that, Lotus must have been aware that they might not get away with it next time so you could argue that they should've done something about it. All of the other cars appear to be able to handle the abuse.
Interestingly, both events have occurred on the short wheelbase E21 with the backward sweeping splitter stay.
