Ferrari F14T
Frafer
Frafer
Re: Ferrari F14T
turbof1 wrote:
Frafer wrote:that RW comes straight from Montercarlo, that's the end of F14T updates i guess
Why so? This particular rear wing is built to produce the most amount of downforce possible. Since Monaco and Singapore are aero-wise close cousins, it's only natural to bring the Monaco spec one.
One shouldn't forget that the current cycle of rear wings is very, very limited in what they can alter and develop, close to being a standard part. Combine that with the fact that the RW regulations haven't changed much since 2009, only further restricting design freedom by removing slots in the wing elements in 2011 and a shallower main plane in 2014, and it isn't hard to see the same wing for the same type of circuit.
100% agree, but i was expecting something like some minor improvements/tweaks, like different slots and/or a new monkey sit. For instance, mercedes have upgraded that parts from montercarlo's one
EDIT 1: even alo yesterday evening said they're going to fully focus on the following season, so.. I believe they're expecting to be faster than williams from this race to the end (more downforce-wise tracks) achieving easily 3rd place on constructor's championship, given their current situation it would be IMHO a well-advised decision directing all aero-department to 2015 car.
Re: Ferrari F14T
Singapore 2014 - Thursday (17.09.2014)
Re: Ferrari F14T
It's relative - for instance Ferrari looked like having updated their front brake ducts. It depends where the team feels they can make the most gains and where to spend their time and resources in it.
Remember: teams are only allowed to do a limited amount of cfd and windtunnel work during a week. They have to make choices.
That being said, Ferrari also still has issues with correlation between simulated data and real time data; I personally believe they are still busy verifying if past updates actually work.
Re: Ferrari F14T
I was hoping to find some diffuser shots. Wanted to see if they're running the diffuser they tested in Monza.....Maybe tomorrow.
.poz
.poz
43
Re: Ferrari F14T
diffuser wrote:I was hoping to find some diffuser shots. Wanted to see if they're running the diffuser they tested in Monza.....Maybe tomorrow.
i don't know if this picture is from Monza or Singapore but omnicorse reports that Ferrari is using the new diffuser tested in Monza
George-Jung
George-Jung
Re: Ferrari F14T
http://www.omnicorse.it/img/articoli/ev ... eriore.jpg
Thats the older one..
zioture wrote:New Diffuser Monza GP
They did not use the new diffusor during the Monza race.. only in FP.
f300v10
f300v10
185
Re: Ferrari F14T
Not sure which of the two cars this is, but it appears to be using the 'old' diffuser:
Re: Ferrari F14T
Singapore 2014 - Friday (19.09.2014)
Gianlu27
21
Re: Ferrari F14T
Giorgio Piola's illustration about the differences between Singapore (similar to Budapest) and Monza
Follow me on Twitter: https://twitter.com/Gianlu_DAle
"Life is about passion thank you for sharing mine" Forza Michael!
Re: Ferrari F14T
Singapore 2014 - Saturday (20.09.2014)
timbo
timbo
111
Re: Ferrari F14T
I wonder if the engine does not have "all out" boost mode, or that it is less radical than on other cars. The relative performance always seem to drop a bit in Q3.
f300v10
f300v10
185
Re: Ferrari F14T
Any ideas on why the F14T was suddenly so competative on a track dominated by low speed traction? For the last several seasons Ferrari has struggled with traction out of slow corners, but in race trim the F14T was the second fastest car and without the safety car Alonso could well have finished second.
Outwardly the F14T doesn't appear to have changed much. The front wing is basically unchanged from the start of the season, and the rear wing looks to be the same as the one used in Monaco. So its hard to see where any significant downforce improvements would have occured. That leads me to believe the power delivery of the power unit has been improved, and perhaps suspension changes. The removal of FRIC could be part of it as well.
Italiano
Italiano
Re: Ferrari F14T
Badly done FRIC-gone. Constant improvement of PU useability and better understanding of the car-in progress. Kimi having slightly more luck-sometimes.... it all adds up.
#Forza Michael #Forza Jules
FW17
168
Re: Ferrari F14T
f300v10 wrote:Any ideas on why the F14T was suddenly so competative on a track dominated by low speed traction? For the last several seasons Ferrari has struggled with traction out of slow corners, but in race trim the F14T was the second fastest car and without the safety car Alonso could well have finished second.
Traction improvements can be done with software updates which they have done through the year. Some of this will be undone when the improvements to the top end power and energy recovery will be done for the next years engine.
Ferrari if serious about the improvements should have put the new engine in a mule, but with all the turmoil in management, guess that was expected.
Re: Ferrari F14T
