daniellammers
daniellammers
Re: Renault V6 Power Unit
Neno wrote:
lio007 wrote:
Neno wrote: nope. renault ended this winter their collaboration with ilmor.
Really, where have you got this Information?
from Abiteboul himself at renault RS17 presentation.
Oh wow, missed that then.
You won't catch me driving a race car that I have built.
- Colin Chapman
lio007
314
Me too!
Neno
Neno
-29
roon
roon
412
With the token system out of the way, how much can teams independently alter their power units?
Red Bull would be the non-factory team with the most money to throw at such a project.
carisi2k
Maybe Illmor will now be building an engine for Red Bull that will be branded Aston Martin. I feel this is why they went with Mobil1 backing. I think Red Bull Aston Martin might be the go for 2019.
That probably won't happen as AM uses Mercedes engines on their DB11. You have a higher chance of VAG entering F1 and siding with Red Bull, than seeing a bespoke AM engine.
djos
113
So the new Renault PU is apparently no slouch in the HP department!
Although Red Bull have found a way to squat their rear end with DRS open which might be a major factor.
"In downforce we trust"
wuzak
wuzak
446
djos wrote:So the new Renault PU is apparently no slouch in the HP department!
https://pbs.twimg.com/media/C5shRT4WUAAZq5k.jpg
Or it could be that they are running less downforce/drag.
djos
113
I did mention the squat to reduce DF under DRS - some pics over here: http://www.f1technical.net/forum/viewto ... 74#p678272
Juzh
161
11kmh faster than hulkenberg's renault and 17 kmh faster than TR. That seems almost too much to be all down to aero/drag.
Cold Fussion
Cold Fussion
93
Surely speed trap data from the first day of winter testing is the most useless of useless data.
227
With more downforce on the cars, they are coming out of the corners at much higher speeds.
Redbull probably coming out of the corners 10km/hr faster than the other cars and so it has a head start to reach its peak speed at the end of the straight.
With these new rules the cars will appear to be more slippery because they are exiting corners much much faster than last year. With the varying quality of chassis, it will also be more difficult to tell which engine is more powerful.
SectorOne
Or it´s just testing you know?
STR is 17 clicks slower than RBR so either STR has a car that car drive upside down at 5km/h or it´s just testing, nobody has the wick turned up to eleven or even remotely near it.
